1994 z28 coolant problem
Old Jul 11, 2012 | 11:12 AM
Z28florida's Avatar
I have a bad leak coming from "t" shaped set up with the 3 hoses with the bleeder screw. The shortest hose on the right side has a crack in it. Trying to figure out the easiest way to fix this. Im new with cars so step by step would be nice.
Thank you
Old Jul 11, 2012 | 12:05 PM
96z28_lt1's Avatar
Re: 1994 z28 coolant problem
depends how far away the crack is. If its not to far you should be able to cut it where the crack is and place it back on if not cut it and splice in another hose same diameter cut to fit and use 2 calmps and hose coupling for the right size. Pictures would help though.
Old Jul 11, 2012 | 03:31 PM
94 heater hoses:
http://shbox.com/1/heater_hoses_93-94.jpg
I suspect he means the return line with part #4 in it.
Old Jul 11, 2012 | 09:24 PM
Z28florida's Avatar
that's definitely it. the u shaped one
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
cmdeshon
Jan 4, 2015 11:15 AM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
