1994 optispark
Old Aug 19, 2003 | 09:09 AM
grygst76's Avatar
1994 optispark
There is only one way this can go back on the motor am I correct? I'm looking at the key and it is hubbed in a way that can only be put one way. Is that the same for inside the motor as well?
Old Aug 19, 2003 | 09:43 AM
94formulabz's Avatar
yes, it's keyed and if it goes on flat all the way you can't screw it up.
Old Aug 19, 2003 | 09:54 AM
grygst76's Avatar
Thanks a lot I'll be doing it tonight and praying to the optispark gods that this is why she died and would not start. The optispark internals would not let me spin them even with a screwdriver!!
Old Aug 19, 2003 | 09:59 AM
Just be VERY careful that you properly align the splines. I don't know how many threads I have seen where people SWEAR they did it right, only to find out when they pulled it apart the second time, they had forced it onto the splines wrong. It is only SUPPOSED to go on one way, but it is very easy to screw it up.
Old Aug 19, 2003 | 10:03 AM
grygst76's Avatar
Thats why as it stands now in my block I moved the crank so that the keyway "hub" is facing perfectly 12:00 and I am going to put it in the opti first---then stick it into the block to be absolutely sure it is in right...good idea huh? Because i noticed you cannot put it in the block wrong since I purposely tried and it refused to go in other then the way it came out. But I could put it in the opti wrong!!
Old Aug 19, 2003 | 10:38 AM
You've got me confused. I thought you were talking about assembling the Opti... putting the splined shaft correctly into the cam sprocket, and into the back of the Opti. But now you appear to be talking about the crank sprocket, keyways, hubs, etc.
Exactly what part are you trying to assemble.
If I misunderstood, I apologize, but the topic appeared to be about the Opti.
Old Aug 19, 2003 | 10:41 AM
grygst76's Avatar
Sorry!! I already have the opti in it's complete form and i was talking about when yo put it back on the motor the sprocket that connects the opti to the motor the long pin type thing.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
scottcba1
Sep 8, 2015 09:52 AM
