1994 LT1 timing set.... advice needed
Old Nov 2, 2006 | 12:33 PM
ZBRA's Avatar
Need a timing set for the '94 Corvette. Looking for the best quality that is a direct bolt in and will work with the stock timing cover and '94 Opti. I will also be using a stock mechanical water pump. What timing set should I buy?
Old Nov 2, 2006 | 02:15 PM
A stock set is about all there is out there, aside from a set from Doug Rippie that costs about as much as doing an vented opti conversion.
Old Nov 2, 2006 | 02:16 PM
Javier97Z28's Avatar
Moderator
If all you have is a stock vette then all you need is a stock timing set.
Old Nov 2, 2006 | 07:21 PM
ZBRA's Avatar
LE2 heads, cam and intake, long tubes, etc. Looks like I'll just put a new GM set back in.
Thanks guys.
Old Nov 3, 2006 | 07:57 AM
93yellowta's Avatar
well I have the Lunati set from summit racing on my car... cc306 cam/ported heads and other mods.. seems to work great. I believe it will fit your 94' if your non vented...
Old Nov 3, 2006 | 08:15 AM
I can't tell the difference in the Lunati from a stock set. The pics even show a GM stamped cam gear. Not sure what is different (if anything).
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
1LEThumper
Jul 14, 2003 12:45 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
