1994 ECU Problem...
Old Sep 12, 2012 | 02:17 PM
94PoloZ's Avatar
1994 ECU Problem...
I have a 94 LT1 and recently put a used computer in it. It would not run with the original, but runs good with the used. However, the check engine light is on and i cannot communicate with computer. Is it just a flashing needed?
Old Sep 12, 2012 | 02:36 PM
mrmint69's Avatar
Re: 1994 ECU Problem...
Some type of scanners have problems with our cars. What type are you using? Do you have the Hypertech programmer hooked up?
Old Sep 12, 2012 | 02:55 PM
94PoloZ's Avatar
Can't remember the scan tool, it was a buddies, but even my hypertech can't communicate. I would think that it wouldn't even run if it needed to be flashed to the VIN.
Old Sep 16, 2012 | 08:56 PM
brandons94lt1's Avatar
I'm running a borrowed stock Pcm in my 94. The Pcm is from a 94 Z... I was going to buy a scan tool but it wouldn't read the Pcm... as was mentioned above, there are scanners that won't communicate with our cars...
Those scan tools i ran across will communicate with 93 and early 94's, but 94&1/2's they won't... I know my car's a 94 1/2 because of the Vin and it also has a traction control light in the dash..
I'm actively seeking a tech1 or 2 GM tool.
You could also buy the cable and use a laptop and the free software to scan your car...
Tunercat I think is the software.. I'm not sure on that... I've been away for a little while.... now I'm picking it back up lol.
Old Sep 16, 2012 | 11:28 PM
There is no difference between and "early" 94 and a "late" 94 with regard to scanning. There is a difference in the fan setup, but that's irrelavent. They did not add a traction control light in "late" 94. There is a "LOW TRAC" light, but that's on all 94's and is used to indicate the ABS has activated.
Tunercat is OBD-I tuning software, not scanning software. Scanning software is TTS DataMaster or FreeScan.
Old Sep 16, 2012 | 11:31 PM
Thanx for the clarification
PopoFormula
Oct 12, 2015 04:19 PM
SEOJustin
Sep 24, 2015 04:39 PM
Formula Steve
Sep 19, 2015 08:48 PM
scottcba1
Sep 8, 2015 09:52 AM
Aug 7, 2015 08:52 AM
