1994 Camaro LT1 Oil Leak
Old Nov 8, 2008 | 09:07 PM
stathread's Avatar
I have not had a chance to look at the car since the time change and work so I figured I'd ask. Anyways, the car is leaking oil and its kind of hard to find. I can see it leaks onto the header (passenger side) and I see the starter looks to be getting oil on it as well. I don't drive it and it smokes since it gets onto the exhaust. It's funny because I never drive the poor thing and now it's having trouble after a short weekend drive to the store
Thanks,
Old Nov 8, 2008 | 09:10 PM
Green96Z's Avatar
Where exactly on the header is the oil leaking? Up top near the primaries or down near the collector? Oil on the starter is most likely the dreaded intake leak.
Old Nov 8, 2008 | 09:16 PM
stathread's Avatar
Looks like it is coming from the top somewhere, I just looked for it for like 5 minutes or so one day from the bottom. What is the "Dreaded Intake Leak", I saw you mentioned it before in the forums. How is it fixed? Is this just a replacement of the intake manifold gasket or something?
Old Nov 8, 2008 | 09:25 PM
LaredoZ28's Avatar
They usually leak oil from the front or the back of the intake where the Black Silicone goes since there is no rubber piece that seals the front and back.
Old Nov 8, 2008 | 09:31 PM
stathread's Avatar
Thanks, I actually did a quick search and found this which seems to be helpful.
http://www.geocities.com/MotorCity/Downs/4013/ol.html
Old Nov 9, 2008 | 01:33 AM
Green96Z's Avatar
This is another good write-up:
http://www.bfranker.badz28.com/fbody/intakefix.htm
Old Nov 15, 2008 | 12:07 PM
stathread's Avatar
Thanks, However I actually got some time today to go out and really look at it. I still did not see anything really related to the intake although I may not have looked well enough. I did however see this, do you think this could be my problem? Its like the fuel rail schrader valve is missing a cap and is quiet wet around it and on the tube. I don't understand if a cap fell off it or what, and I don't know if this could be the leak so I suppose I will head back out there to smell around. Here is a photo...
By the way it's located on the back of the intake.
This is a photo of after I drove it down the street and back, notice it already showing signs of leakage.
Old Nov 15, 2008 | 12:26 PM
LaredoZ28's Avatar
I dont think putting a cap on that fuel rail will solve your oil leak problem. in the pic you took i c that there is black under the fuel rail. It still looks to me like the back of the intake where it sits on the block is leaking.
Old Nov 15, 2008 | 01:17 PM
stathread's Avatar
Yeah you're probably right, that cap missing is not a problem. ugh.
Old Nov 15, 2008 | 02:45 PM
LaredoZ28's Avatar
i'd make sure that the fluid on the fuel rail isnt fuel. If it is i'm sure a new stem in that thing will fix it.
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
blac94Z
Nov 28, 2014 01:53 PM
thenewkid
Nov 27, 2014 09:41 AM
dreamer1q
Jul 24, 2002 04:39 PM
