1993 Speedo Correction
Old Sep 22, 2004 | 09:29 PM
RedScreamin's Avatar
I have a 1993 Trans Am with the 4L60 transmission. I currently have stock 3.23:1 rear gears want to install 3.73:1 rear gears. The only thing is that with the non-electronic transmission that came in the 93's I can't use a hypertech or anything to correct the speedo. Does anyone know how I can correct the speedo if I install the gears? I emailed PCMforless.com and they said they can't do it.
thanks
Old Sep 22, 2004 | 09:54 PM
ltwonz's Avatar
Re: 1993 Speedo Correction
Change the two gears in the trans. One is on the tailshaft and the other is with the VSS. It really isn't that hard to do at all.
Old Sep 22, 2004 | 10:08 PM
n2ceptor's Avatar
http://www.sallee-chevrolet.com/Chev...tallation.html
Scroll down to speedo calibrations.... It not hard to change... Just just the calculation that is given...
Fastbird93's Avatar
Do a search for "drive and driven gears." Those are the two that need to be swapped out for the speedo correction.
Old Sep 23, 2004 | 06:09 AM
Thanks a bunch. One more Question, how hard is it to perform that swap?
Old Sep 23, 2004 | 06:16 AM
Which gears come stock with it? Or can I just use the formula with any drive teeth gear I want and make sure I put in that gear woth the matching driven gear?
G-BODYT56
Jan 14, 2022 11:14 PM
NewsBot
Sep 30, 2015 04:20 PM
drt
Sep 27, 2015 04:39 PM
4586
Sep 27, 2015 01:55 PM
mmf_1013
Sep 12, 2015 08:56 PM
