1993 Speedo Correction
I have a 1993 Trans Am with the 4L60 transmission. I currently have stock 3.23:1 rear gears want to install 3.73:1 rear gears. The only thing is that with the non-electronic transmission that came in the 93's I can't use a hypertech or anything to correct the speedo. Does anyone know how I can correct the speedo if I install the gears? I emailed PCMforless.com and they said they can't do it.
thanks
thanks
Re: 1993 Speedo Correction
http://www.sallee-chevrolet.com/Chev...tallation.html
Scroll down to speedo calibrations.... It not hard to change... Just just the calculation that is given...
Which gears come stock with it? Or can I just use the formula with any drive teeth gear I want and make sure I put in that gear woth the matching driven gear?
NewsBot
Sep 30, 2015 04:20 PM
