1993 Injector Replacement
I have searched and can't find an answer to this question, so I thought I would post up herer. I am going to need to replace the injectors in the 1993 LT1 I am swapping into another vehicle, and did not know if any other year's injectors were compatable.
I am aware the 93 is batch fire and later models are sequential, but can I use a later year model injector in the 93 motor?
Thanks!
Ed
Thanks!
Ed
I have 42# SVO injectors in my 93, but expecting bigger and better things in the future. The 93 only has a COMP CAM and JH LT's. PCMFORLESS did the tuning and the A/F is now Perfect!
I agree with the previous post, it is too risky to make that type of change and not dyno with an A/F ratio. My stock injectors were bad and the A/F was 18-1, Mike Norris of Norris Motor sports shut it down to save the motor while it was on the dyno.
Jim
Jim
All you have to do in the ECM is change the injector constant.
I went all the way up to 42's without changing anything in the computer except the injector constant. It automatically scales down all the fuel tables to compensate.
Mike
Mike
Alex Barnes
Jan 24, 2015 10:21 PM
Sarahrope64
Nov 27, 2014 11:17 AM
Jul 4, 2005 05:00 PM
