195 degree thermostat
Old Nov 12, 2015 | 10:00 PM
frankrizz's Avatar
Are there any long style 195 thermostats that will fit my 94lt1. I am currently using a 180. I think I should be running hotter. I never reach
the 190 mark. My radiator fan comes on at 185. Please note this Lt1 is
transplanted into an older ford.
Old Nov 12, 2015 | 10:17 PM
Re: 195 degree thermostat
Stock is 180. Don't know about the availability of a higher temp one. Why not adjust the fan ON temp? That will give you the best control of engine temp.
Old Nov 13, 2015 | 08:57 AM
The LT1's "reverse flow" cooling system is the reason for the 180* t'stat. In effect, with the coolant hitting the heads first, and then being heated up by the lower block, its one of the reasons the engine is able to run a higher compression ratio and aggressive ignition timing. By the time the hot coolant comes out of the engine, it is the same temperature as coolant from a conventional flow system.
The fan on/off temp's are controlled by the PCM, based on the coolant temp SENSOR (not a "switch") readings. To change the fan on/off temps, the PCM needs a new flash program. Or, a Hypertech handheld tuner can make the changes. This assumes your PCM is from a 94-97 model. 93 is different. It would help if you added a "Signature" so we know the details of the vehicle/engine/controls combo. There are a lot of subtle variations from year-to-year in the LT1's.
Is it possible your cooling system has been modified to use a switch to control the fans, rather than the CLT sensor/PCM? I ask, because in another thread you asked about using teflon on the threads of a temperature SWITCH. This would explain DTC 77, which you reported in another thread.
Old Nov 13, 2015 | 09:30 AM
lt1-xjs's Avatar
I would consider yourself lucky and leave it alone. Most strive for cooler running temps and usually run 160* thermostats including me. Mine stays around 170*.
LingenfelterZ28
Apr 24, 2015 02:00 PM
mspennyhughes
Mar 1, 2015 03:50 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
