160 thermo stat ?s
Old Oct 2, 2004 | 05:09 PM
budvol's Avatar
160 thermo stat ?s
Do I just go to Autozone of somewhere and ask for a 160? Or is it a special one?
Also does it do anything in the computer or something?
Old Oct 2, 2004 | 05:13 PM
budvol's Avatar
Re: 160 thermo stat ?s
Autozone has a HYPERTECH THERMOSTAT 160 DEGREE THERMOSTAT for a 1993 CHEVROLET CAMARO
is that what I get?
Old Oct 2, 2004 | 05:18 PM
Z95m6's Avatar
yes, that will work. It should run around $20. Most autoparts places will try to give you the one for a std. SBC and they are only a few dollars but they won't work.
Old Oct 2, 2004 | 05:22 PM
budvol's Avatar
Do I just pop it in and thats it? Its a 1993 LT1,, no re-programming?
Old Oct 2, 2004 | 05:26 PM
Z95m6's Avatar
nope you don't need any programming. You might have to bleed the coolant system after your done. Other than that its just a simple thermostat install. I would probably put silicone around the housing though because if it leaks any its all gonna land on the opti.
Old Oct 2, 2004 | 05:33 PM
Short procedure.
Old Oct 2, 2004 | 06:48 PM
budvol's Avatar
Where is the PCM BAT fuse?
Old Oct 2, 2004 | 07:02 PM
n2ceptor's Avatar
Open the driver door, look at the side of dash, removable panel, fuse box...
Old Oct 2, 2004 | 07:23 PM
Z95m6's Avatar
its been a long time since i pulled it but i believe the pcm fuse is in the fuse box on the drivers side under the hood.
Old Oct 2, 2004 | 07:38 PM
budvol's Avatar
What does it do when u pull it? and does the ing key deed to be on or off
Old Oct 2, 2004 | 07:42 PM
Z95m6's Avatar
Why are you pulling the PCM fuse if you don't even know what it does?
Old Oct 2, 2004 | 07:49 PM
budvol's Avatar
Good ?
I guess it resets the PCM
I'm new at this NEW car stuff the last car I had was a 1968 Impala with a 327,,, before that it was a 1978 Z28 I had for 20 years.
Never owned a car newer than that!!!
They did not have this crap on um!
Old Oct 2, 2004 | 07:58 PM
Z95m6's Avatar
That still doesn't explain why you are pulling the pcm fuse. If you are pulling it for some reason related to the thermostat install. I'll just save you the time. You don't need to pull it.
Old Oct 2, 2004 | 08:02 PM
budvol's Avatar
I wonder why my overheat light is coming on at just 190 or so...it shouldnt come on at that temp should it.
What temp sould the light come on at ? And is that set in the PCM?
Old Oct 2, 2004 | 08:06 PM
Z95m6's Avatar
I didn't even know there was an "overheating" light. I guess i've never had that problem. I do know there are 2 temperature sensors on the car maybe one is bad. That might be why your gauge reads fine 190 and the other one thinks the car is getting hot.
