160 thermo
Old Feb 25, 2010 | 12:41 AM
93_ZZZZ's Avatar
160 thermo
If i have a 160 thermostat would that keep the heater from getting very warm? or should it still get hot inside? New car to me and has a 160 thermo i believe plus fan mod. Temp guage only gets about a 1/4 of the way up.
Old Feb 25, 2010 | 12:54 AM
69z-28's Avatar
i had a 160 in my T/A during the winter and it wasn't bad, although if you want hotter heat, a 180 will help.
Old Feb 25, 2010 | 01:31 AM
93_ZZZZ's Avatar
I also do not currently have a headliner so that may be hurting as well lol, but it just doesn't really get warm i can drive down the highway and it will be cool inside, maybe i need to flush the heater core
Old Feb 25, 2010 | 05:18 AM
The problem is you have a 93, and the 93 coolant temp gauges are mis-marked, making you think its running cooler than it really is:
Courtesy of Shoebox:
http://shbox.com/1/temp_gauges1.jpg
With a 160*F t'stat and reprogrammed fan on/off temps, I had no problem with the heat in my 94, in NJ weather that can get as low as 0*F. You may have a bit of sludge in the heater core. Try flushing it out.
Old Feb 25, 2010 | 11:12 AM
thebufenator's Avatar
I currently have a 160 T-stat, heater works fine too.
Temps barely get past the 160 mark. How much does that decrease mileage?
Old Feb 25, 2010 | 08:10 PM
93_ZZZZ's Avatar
Okay i will do the flush seems to be a pretty common thing around here. Plus the heater hoses, do they separate at that bracket or do you have to buy them as a pair?
Old Feb 26, 2010 | 01:29 AM
19camaro71's Avatar
I had just replaced my heater core when i put in a 160 stat and noticed a definite difference in heat when I did this.
Old Feb 26, 2010 | 09:09 AM
Heater hoses (courtesy of Shoebox):
http://shbox.com/1/heater_hoses_93-94.jpg
Old Feb 26, 2010 | 10:24 AM
n2ceptor's Avatar
I run a 160 w/ hypertech thermomaster chip with no issues for heat in winter...
Old Feb 28, 2010 | 12:15 AM
Fatdog2's Avatar
The heaters in f-bodies are not very good.I would stay with a 180,and I live in ca.
Old Mar 9, 2010 | 12:04 PM
93_ZZZZ's Avatar
It wasn't my thermo has a leaky heater core but it was sludgy and not dripping yet on the carpet. heater works great now even with 160 thermo.. thanks everyone
Old Mar 9, 2010 | 05:16 PM
Yes. A clean heater and a 160* t'stat will provide more than adequate heat.
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Mar 26, 2016 08:53 AM
Javier97Z28
Sep 8, 2002 07:23 AM
99TransAmWS6
Sep 2, 2002 11:41 AM
TrouserSnake
Aug 30, 2002 04:14 PM
