160 degrees, worth it?
someone tell me if im doing this right, i run the engine til its warm, then open the bleeder screws until nothing but a stream of coolant comes out right? well last night when i did it i got a litle puff or two of air, and thats it, this morning nothing comes out at all, air, coolant, nothing. i must be doing it wrong.
guidance please??
guidance please??
I installed a 160* stat with a 176/on 166/off fan switch, and not only does my car run cooler but it also has more power(even if I did lose about 1 mile per gallon).
I know that LT1's and L98's are programmed a bit differently=) (mine ran at 220* cruising and the fan was 243/on and 223/off with a 195* stat) but you should notice a bit of difference.
I have the 160* T-stat in my car and it always runs between the first 2 marks, after I put the programmer on it. The only thing I really hate about the T-stat is that the Heat never really gets hot in the car during the cold winter months. And you know it sucks sitting in a cold car.
RUENUF
Mar 13, 2016 03:37 PM
