160 Degree Thermostat
Old Jan 4, 2004 | 05:22 PM
My 97 Z28's Avatar
Wondering how much a 160 degree thermostat really helps the cars? Any modifications I would have to do to install one?
Old Jan 4, 2004 | 05:41 PM
Red_94Formula's Avatar
from what i learned 180 is better for power. gas will burn at the most efficent rate at around that temp. going hotter or cooler can hurt hp a little.
i went from 160 to 180 once i found that out. do a searce on it. someone dyno'ed thier car to prove that 180 is actually better.
unless your running a blower, nos, turbo or high timming stay at 180.
Old Jan 4, 2004 | 05:47 PM
ibanez6rg's Avatar
I've never heard this.
Old Jan 4, 2004 | 05:53 PM
AxeGrinder30thZ's Avatar
Me either.
Old Jan 4, 2004 | 06:11 PM
i could not find the dyno post but i did find some info to back me up in this post http://web.camaross.com/forums/showt...&highlight=160
also with fans set at 160 and electric water pump and watter wetter with the 160 thermo i could never get any lower then 167 degrees. but thats with a cam that heats things up quite a bit. but point being you need a a electric waterpump and have you fans set low to even see a major drop in temp with the 160.
now i stay at 180 now matter what weather we get here in Boston.
Old Jan 4, 2004 | 06:50 PM
zoso1959's Avatar
Lightbulb a thought on temp
please correct me if i'm wrong, but if he's looking to put in a 180 thermostat to get that temperture, wouldn't he get that with the 160 stat?
i thought i read in a post that someone had taken one of those heat temperture tools and tested the temp of the coolant and a 160 stat was actualy running close to a temperture of 180 degrees?
zoso
p.s. so a 180 stat, my run close to 200 degress?
Old Jan 4, 2004 | 08:28 PM
ChickenScreamer94's Avatar
A 180* stat will really make your engine run at about 190*. The thermostat OPENS at 180*, so the coolant can never get below that.
My 160* stat makes my car run at about 170* cruising. I have an auto xray to confirm all of this
I dont know if the cooler temps reduce hp, since there is a fine line between too cool and too hot on these motors, but i think it my reduce it a little. My MPG has remained the same virtually, down about .3 MPG. No biggie to me.
Old Jan 5, 2004 | 01:17 AM
Eliminator's Avatar
I have a 160 thermo. and it even the wrong type of one its for a older LT1 and I never had any over heating problems or performance issues with it I have the MR.G 160 for older LT1, I ordered the wrong one and just found out a little while ago but its in storage now so spring time I will replace it with the correct thermo.
Old Jan 5, 2004 | 01:22 AM
GhostZ's Avatar
Um....nope.
Old Aug 15, 2019 | 06:37 PM
Bob Calhoun's Avatar
Re: 160 Degree Thermostat
Really I think you need to research your reply
Old Aug 17, 2019 | 10:48 AM
Leeman's Avatar
Have had a 160 in mine for 20 years. I'd recommend a little higher if you'd like heat out of your heater in the winter. :-)
Old Aug 17, 2019 | 10:53 AM
15+ year old thread, full of bad info.
Old Aug 17, 2019 | 11:12 AM
Germansheperd's Avatar
Lol
Old Aug 18, 2019 | 06:43 PM
94Z28LS1toLT1's Avatar
Dan94Z28RO
Jan 11, 2004 01:40 PM
ba96ta
Oct 12, 2003 10:48 AM
O2Bsogood
Jul 18, 2003 05:25 PM
lmissry
May 29, 2003 04:09 PM
Ferocity02
May 25, 2003 12:44 PM
