160º Thermostat
Old May 20, 2003 | 09:45 PM
Ferocity02's Avatar
160º Thermostat
I am interested in getting a 160º thermostat for my car because well many people have one and they wouldn't if they didn't like them....... Anyways, how do they work, and how well do they work. Also, is it safe to buy a used one? Thanks alot!
Old May 20, 2003 | 09:58 PM
sleeperZragtop's Avatar
Re: 160º Thermostat
I wouldn't buy a used one...that's just me...as for them working well...it works best with a HPP3, LS1edit or any other tuning...this way you can adjust it so your fans will come one earlier...other than that without tuning your car will run a little cooler...
Old May 20, 2003 | 10:06 PM
camaro322hp's Avatar
Re: 160º Thermostat
160º
nice use of "alt0176", impressive, thought i was the only one who used that
i used the hypertech 160° thermo in conjunction with the HPP3 install. i don't know that the thermo alone will get you much without the power programming and fan programming. it runs a little cooler now, noticeable on the stock temp gauge.
Old May 20, 2003 | 10:11 PM
Ferocity02's Avatar
So don't bother unless I get a power programmer? Because I don't plan to, to damn expensive
Old May 20, 2003 | 10:17 PM
Well...alot of guys do that mod without a programmer...it just works better...IMO it's a cheap good mod....do it, I did
Good luck man
Old May 21, 2003 | 12:06 AM
Flat_Tire_'s Avatar
You don't need an HPP3 to get the fans to come on earlier. You can buy the $60 SLP fan-switch mod which allows you to turn on your cooling fan manually, and when the switch is off, the fans act automatically ...
I myself have the 160 themrostat and noticed a huge drop in temp during highway driving but no difference in stop and go city driving ...
I haven't bought the fan switch yet but plan to. Anyone else out there buy it and install themselves, how long did it take? Easy to do?
Old May 21, 2003 | 01:04 AM
Geeterman's Avatar
As long as the car is moving, it will run cooler. I recommend getting it.
Old May 21, 2003 | 05:13 AM
2001NBMZ28's Avatar
I have the SLP fan switch - easy install. It plugs right into the stock connector.
Old May 21, 2003 | 09:51 PM
petegz28's Avatar
A 160 will begin trying to cool the car at 160 but doesn't mean it will make the car run at 160. Every car finds it's own spot. Keep in mind on the LS1 running a 160 may over time cause engine problems because the engine parts aren't being allowed to expand from the heat. There is a certain amount of heat compensation the factory took into account whent hey built the engine. And the LS! being mostly aluminum you already discharging heat a lot better than an LT1 let's say.
Just some food for thought. I run the 180 myself.
Old May 21, 2003 | 10:38 PM
#7's Avatar
Yeah easy,the hardest part was getting that gromet back in behind the PCM made my finger raw.
The switch is cool 2 speeds of fan also.
Old May 25, 2003 | 12:44 PM
99sixspeed's Avatar
I run a bottle of water wetter with a 90/10 mix of water to antifreeze and going by my predator my car runs about 190-193* all the time. BTW the gage always reads 210* The car never drops off power even when I hot-lap it at the local track and the temp never climbs over 193*.
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
chevy94c
Mar 26, 2016 08:53 AM
Bobczar
Oct 23, 2015 11:22 AM
MikeWhitener
Aug 2, 2015 06:17 PM
