160* thermostat
Old Jan 29, 2004 | 05:08 PM
camaroguy94's Avatar
160* thermostat
i am gonna get a 160* when spring comes around. whats the difference between the hypertech and the regular autozone ones for $4.99? should i get the hypertech or jus go with the cheap one?
Old Jan 29, 2004 | 05:20 PM
ATMINF's Avatar
The Auto Zone one is probably just for a regular chevy smallblock.
Old Jan 29, 2004 | 06:00 PM
ibanez6rg's Avatar
Just make sure you get one for reverse cooled heads.
Old Jan 29, 2004 | 07:43 PM
Eliminator's Avatar
I did that when I first bought my car the guy said it was for my year car, then I looked a Shoeboxes website and found out I have the wrong thermo installed. It never ran hot and I never noticed the diff. between them the Mr G. 160 and the Hypertechs but I hurried and changed it out to a Hypertech stat.
Old Jan 29, 2004 | 08:46 PM
LameRandomName's Avatar
The real LT1 thermostat controls flow in both directions, ostensibly to prevent thermal shock to the heads from excessive cold water.
Old Feb 9, 2004 | 11:44 AM
Tires_Smokin's Avatar
I ran my engine with no thermostat for 100 mi cuz I was stuck in the mountains and my stock stat got stuck closed. I wonder if my heads were affected for driving at 230 temp with the stat closed before I fixed it. I have the Hyp 160 stat..use that or just stay with the 180 stock stat?. And why?
Old Feb 9, 2004 | 11:53 AM
235º should not be a problem. The stock secondary fans don't even come on until that temp. You can find some ramblings about the 160º thermostat here.
Old Feb 9, 2004 | 12:34 PM
350 HRSS's Avatar
They didn't list a 160* for a 94-95Z at AutoZone or Advance when I checked. They only listed the stock 180*.
As far as I know, only Hypertech makes a 160* for 93+ F-bodies.
Old Feb 9, 2004 | 01:02 PM
well im not sure what the manufacturer of the 160* at autozone but it was only 4.99 they also had the hypertech there for like 23.
Old Feb 9, 2004 | 02:35 PM
The $4.99 one is the wrong style. It is the old SBC one and not made for the reverse flow LT1.
Old Feb 9, 2004 | 02:41 PM
rpm4lalo's Avatar
I use the Hypertech 160, but there must be a lower cost alternative.
Old Feb 9, 2004 | 02:58 PM
There really isn't.
Old Feb 9, 2004 | 03:59 PM
moparman's Avatar
I think Motorad is the outfit that makes the 160 t-stat. If you can find someone who sells Motorad, it might be cheaper.
Jeff1904
Jun 5, 2016 05:00 PM
MikeWhitener
Aug 2, 2015 06:17 PM
kylekratzenberg
Jun 29, 2015 05:56 AM
Biggiebound
Apr 23, 2015 08:50 AM
VetteThreat
Jun 18, 2002 01:53 PM
