15w50 motor oil
Old Aug 29, 2004 | 02:55 PM
  #16
FastZinTennessee's Avatar
Re: 15w50 motor oil
Originally Posted by 94 CAMRO Z28
We run a GM Performance Parts crate motor in our late model stock car. The engine brand new calls for Mobil 1 15w50.
Aaron
Then I'm sure that the bearing clearances are looser from the factory. I've seen newer motors calling for as light as 5w20.
I've had to pour some 15w50 oil when it was about 40* outside. It took me about five minutes to empty a quart bottle into the crankcase. It's just unnecesary. Honestly, the 0w40 that I had in the Camaro was probably too heavy for what I was doing also.
But in any case, do whatever makes you feel more comfortable. If you use oil that's too heavy the only downside will be loss of power from pumping. In extreme cases maybe a little more wear on startup because the oil won't pump to where it needs to be fast enough.
HectorM52
Jul 30, 2017 11:46 AM
Dmonty
Jun 2, 2015 11:19 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
transam_388
Mar 15, 2015 11:53 AM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
