15.4's in 1/4 Mile
Well, I forgot to tell you all I had a really bad fuel prob. So I bought a new gas tank, new fuel pump, fuel filter..then found out there was 2 lines back words. After I put them all in. Do you think this could of made my motor fry the rings or anything, Yes it missed out like driving around town like eveyone other time I drive it
But at the track it missed out around 5500 - 6000
I cleaned the T/B but I belive I will do it again, Might help I dont know.
If you all could think of some where I could get my plug wires done asembled I would order them today or tomarrow
I have a warr. on the Plugs so i am going to change them to at the same time.
The fuel pump is only like a month old (Fuel filter to) So I should have good pressure but Will check also
What is seafome this guy told me to do that??!!
Also I am not getting any Codes, My Transmission is rebuilt like 2,000 miles ago with a shift kit.
Oh yeah at the track I can tac my car up to 2 grand with out spinning and my tires a really blad is this normal? That might help with my problem
But at the track it missed out around 5500 - 6000I cleaned the T/B but I belive I will do it again, Might help I dont know.
The seafoam treatment flushes the motor of carbon. YOu can pick up a can of it at Napa for about $6. The find you a good vaccum line from the intake (i.e. the PCV valve will do) and pour a little in the cap and let the line suck it into the motor. Your motor might "bog" down a little but this is normal. Also it will white smoke for a little while but this is it "steam cleaning". It works great.
