14.3 @ 96 mph Please look inside, is this slow?
Old Jul 6, 2003 | 07:20 PM
Durbn4duke's Avatar
That was my time on street Kumho 275/40/17 on a hot humid day July 1st at Rt.66 is this a slow time for my mods below,.. i know i have nothing major and no hedders. its also an auto.
Old Jul 6, 2003 | 07:28 PM
"White Knight"'s Avatar
nope seems good to me.......i run a 13.987 with
slp headers 1 3/4"
B&B tri-flow exhaust
subframe connectors (just weight...lol)
Cold Ait Induction
Air Foild in throttle body
high flow cat
and mines an auto too.......those 2.73 don't help......lol
also how how was your engine running and how hot outside???
Old Jul 6, 2003 | 07:33 PM
KeVMaN's Avatar
some camaros get close to mid 13's with intake/exhaust, so it would have to be pretty damned hot outside for that to be a good time. What's your 60 ft? it should be fairly low w/ those tires
Old Jul 6, 2003 | 07:38 PM
revtime's Avatar
I ran a 13.6@102 with CAI, ypipe, catback, PCM tune, and 3.73s.
Weather makes a big difference.
Old Jul 6, 2003 | 07:55 PM
Snoochies's Avatar
Heat is definitely a huge factor in how LT1's run. Last summer I ran three straight 13.6's at 101.5 to 102 mph. It was really cool out, nighttime and perfect conditions. A few weekends ago I went again, but on a Saturday around 1 in the afternoon, freaking 95 degrees out and my car was running at like 240 degrees. It really sucked. My best was a 14.0 at 97.5 and a worst of 14.2 at 96. I'm definitely waiting till it's cool out to go again. Quote "What's your 60 ft? it should be fairly low w/ those tires?" I almost guarantee you'll drop a tenth or two with some decent drag radials. Also not all automatics have 273's.
Old Jul 6, 2003 | 07:56 PM
TsRfBoDy's Avatar
I pulled a 13.7 with a nitto and an CAI, not even exhaust and it was 70 degrees out, so I think u should be able to get a lot more out of that car and mine is auto
Old Jul 6, 2003 | 08:51 PM
CamaroGuy22's Avatar
I think thats very slow time...was it really hot/humid outside? and did your 60ft really suck? Stock auto verts run faster than that...and that trap is def not close.
Old Jul 6, 2003 | 09:10 PM
colorchange96's Avatar
even if his 60' foot sucked, the mph would still be there. i dont think your car is running right.
Old Jul 6, 2003 | 09:15 PM
silver97Z's Avatar
Mine ran a 13.5@100 on a cool afternoon...auto, 3.73, eibach springs, bmr relocation brackets, drag radials (274/40 17), bmr panhard rod, cai, and loudmouth catback with a 2.0x short time.
Old Jul 6, 2003 | 09:18 PM
Good point..i agree
Old Jul 6, 2003 | 09:45 PM
SunCoastTA's Avatar
My quickest was a 14.4 @ 95 with 2.1 60ft. Its an auto, mods are in sig. If this helps
Old Jul 6, 2003 | 09:46 PM
CamaroBoy96Z28's Avatar
I second that. I ran 14.09@99 bone stock with a 2.2 60' on BFG G-force KDWSs. On a slipping clutch I ran 13.80@103.7 with a 2.16 60' on my Drag Radials with CAI, pulleys, catback, TB bypass, and LCAs. It was probably ~60* out.
Old Jul 6, 2003 | 09:50 PM
BRIAN93Z28's Avatar
Hmm...well my 93 Z28 automatic went a best of 13.7@103.3mph bone stock, and i got it down to 13.2@107.5 with simple bolt ons on the stock torque converter and street tires, that run was on a 2.143 60ft. A lot of it has to do with weather and how the track is prepped, but i would be a little dissatisfied with that time, i would be hoping for at least a 13.6-13.7. And i think you should be seeing at least 101-103mph traps. But some cars dont respond too as well to mods as others, just an incentive to do more mods. Get yourself some gears and a torque converter and youll be ripping up the 1/4 mile track! Good luck bro
Brian
Old Jul 6, 2003 | 10:04 PM
94formulabz's Avatar
revtime hit it on the head. I don't know the altitude at rt 66, but that can play too. People really should list their time and corrected time for effective elevation. You can only claim your real time on your slip, but for purposes of comparison adjusted times are appropriate. With the weather correction (somewhat cool but very humid added 1000' effective elevation) my best time becomes a 13.16 and i'll use that when i got back and get a new time with headers and compare them.
Your time sounds decent with your description of conditions and mods, or lack there off
edit* weights are also very helpfull. I'm not sure what i'm at but i don't have any reduction other than pulling the spare tire.
Old Jul 6, 2003 | 10:35 PM
Antz97ZNJ's Avatar
you should be in the higher 13's over 100 mphs...I wouldnt be satified..slowest i ever ran in my 97 was a 14.1 w/ a flow. muffler and i couldnt drive for crap at the time
