13.7:1 Afr
13.7:1 Afr
I am having a new fuel pump and McLeod Street twin put in and I wanted the shop to do a before and after dyno run. He did the before and said my AFR was steady at 13.7:1
but the car still managed to put down ~340RWHP on a Mustang dyno. So now after he gets the stuff installed he is going to tune it back to the 12.5-12.8 range. How much power do you think I will gain from that?
Why would you want to make it richer?! 13.0-13.2 is good and safe, stock af in PE mode is 11.7, which is waaay to rich.
If you're safe at 13.7, stick with it.
BTW, you will LOSE horsepower if you make it richer!!
Re: 13.7:1 Afr
I am hoping I will gain some more power because he also said that the car was pinging from being so lean. When he tuned it a year ago he had to pull out so much timing to get it to run without knocking at 12.8:1 that it actually lost power from when he had it set at 12.5:1 with the timing put back in.
Plus I would definitely feel safer running in the 12.x:1 range when I put the bottle on the car.
12.5 is good for a blower car, but generally too lean for an NA car. But a major reason to tune is to find out what works best. You may gain power, lose power, or it may make no difference. In general ~13-13.4:1 works best for an NA LT1.
Rich Krause
Rich Krause
mine when it was stock was hitting 11.1 or 11.2 at wot in pe mode. but when i got it programed to 13.0 there was a ig increase in power. what you need to do is go get your car put on a wide band o2 dyno and they can tell you where you make the most power (A/F ratio wise)
13.7 is to lean for my taste
Sometimes its not all power... its smoothness.. maybe the car runs smoother with a bit more fuel...
I like to tune for 13.0:1 for NA and 12.3:1 for forced induction...
The thing is that 13.6 as happened with latinspace... its the result of measuring though the exhaust and not the headers... so it was nice at 13.6
RUENUF
Mar 13, 2016 03:37 PM
