12499224 LS6 Yellow Springs
Old Nov 5, 2006 | 07:32 PM
Kwik89GTA's Avatar
Will the 12499224 GM LS6 "yellow" springs work on a LT1 in place of the 918 beehive springs? They are substantially cheaper. It looks like you could use them with the Comp Cams LT1 beehive retainer, but I can't be sure.
Anyone have these on a LT1?
Old Nov 5, 2006 | 07:35 PM
jay_lt4's Avatar
should work fine,but they are only good too .550" lift
Old Nov 5, 2006 | 07:47 PM
Kwik89GTA's Avatar
Sounds good, I'm running the CC305 with the LT4 1.6 roller rockers. Should have lift right around .544. SDPC lists the yellow springs as good for .588 lift but GM parts Direct lists the maximum lift as .550. I still think that I should be safe either way......
Old Nov 5, 2006 | 11:57 PM
SStrokerAce's Avatar
Yes and no, not as much pressure or lift potential as a 918. Belive me Lloyd and I have looked at using them for the LE1 package but that wasn't going to work.
Bret
Old Nov 6, 2006 | 05:31 AM
Kwik89GTA's Avatar
Do you think that these springs will be fine with the CC305 and 1.6RRs?
Old Nov 6, 2006 | 12:56 PM
Depends on how many good ones you get in a batch..... With 1.5's and them installed tight enough yes. There is not enough seated pressure if you set them up too high.
Bret
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
R@mpage
Apr 20, 2015 10:02 AM
racecarz28
Mar 30, 2015 09:55 PM
LT14LIFE
Feb 9, 2015 09:35 PM
