12 bolt fluid (synthetic vs standard)
Old Dec 24, 2003 | 04:32 PM
atljar's Avatar
I have a strange 12 bolt and its time to change out the fluid. Strange told me to use non synthetic oil. Any reason for this? I would really like to run royal purple w/ gm additive.
Old Dec 24, 2003 | 04:33 PM
S.J.S.'s Avatar
Whats strange about the 12 bolt??? Nah jk. Anyway, I would use exactly what they say to use my man. Can't go wrong. Not to mention it'll be cheaper.
Old Dec 24, 2003 | 04:36 PM
atljar's Avatar
I think its just a little wigged out from all the 6k clutch drops
Just perfer royal purple everything, any extra 1-5 hp i can muster out of the car is good in my eyes.
Old Dec 24, 2003 | 05:03 PM
meengreen 94z's Avatar
I wouldnt use Royal Purple in anything. I switched to it from Mobil 1 syn. and had a lifter collapse. Since then Ive heard all kinds of stories, even cases of the oil dissapearing after a couple passes at the track.
Old Dec 24, 2003 | 05:29 PM
97WRAITH's Avatar
I just got my 9" Moser and they also said not to use synthetic.
Old Dec 24, 2003 | 05:43 PM
HBHRacing's Avatar
Moser says to use non synthedic due to the friction needed for the posi to work correctly
Old Dec 24, 2003 | 05:45 PM
97WRAITH's Avatar
I am using a locker.
Old Dec 24, 2003 | 05:46 PM
rskrause's Avatar
Moderator
If it has a friction type posi, synth will be too slippery and the posi will not work properly.
Rich Krause
Old Dec 25, 2003 | 01:40 AM
atljar's Avatar
Well, i never even thought about the posi needing something less slick. Its the heavy duty Eaton unit, but i guess ill stick with standard. Thanks!
Old Dec 25, 2003 | 07:09 AM
rskrause's Avatar
Moderator
Absolutely! The Eaton is a clutch type posi and will not work as well with synth.
Rich Krause
Old Dec 25, 2003 | 07:53 AM
97WRAITH's Avatar
You can add a bottle of GM friction moddifier.You can pick it up at the dealer.
Rob.
Mid-life Toy's Avatar
The best way to get "thee" answer is to go directly to the manufacturer of the product being discussed. Meaning, I have a Moser 12 Bolt in my 94Z M6 which includes an Eaton Posi. So, I went to the Eaton web site and printed out all the info I needed about my unit. I also called up Eaton and they advised me "NOT" to use synthetic gear oil as it might harm the clutches in my unit. Therefore, I only use "mineral based" gear oil.
Note: The seller of products is not always the expert. I actually called Moser about the gear oil and talked to several folks and received different answers. That is why it is always best to go to the manufacturer if possible. Better to make a decision on actual facts and not someone's opinion. An old saying applies here: "20 years of experience and 10 minures of knowledge." While a lot of folks have experience they do not really have the knowledge to make the most accurate decision.
A happy and safe holiday to all.
rideordie
Nov 5, 2019 04:52 PM
maybe2fast
Mar 16, 2015 09:45 AM
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
