112 LSA w/ Nitrous
Old Jan 22, 2004 | 10:23 AM
PROJEKT Z28's Avatar
112 LSA w/ Nitrous
I am thinking of adding a 75-100 shot on my car with the mods listed below.
Car dynos about 315 RWHP (mild head port) and I am looking for more, occasionally.
Anyone spray 100 shot with a 112 lsa 224/230?
Disadvantages to the 112 lsa?
Old Jan 22, 2004 | 11:03 AM
Nostang 96z's Avatar
My cam is a 235i 242e .568 .592 112lsa cam and I run the times in the sig on a 150 shot. I went with the 112lsa to give me a little more power N/A and it works very well for the bottle too.
Matt
Old Jan 22, 2004 | 11:10 AM
Larnach's Avatar
Man that car is flying on that 150 shot!
OH, thanks alot PROJEKT, I click on your website thinking it will be an actual site about a car... Good thing I'm not at work.
Old Jan 22, 2004 | 11:11 AM
GetaZforgetGT's Avatar
I wouldn't call it a disadvantage.
A larger SLA would help to increase your cylinder pressure and get the most out of you Nitrous setup.
There are a lot of guys out there that build for N/A power and consider the Nitrous power as a bonus so they run a tighter LSA for all around driving fun.
A 112 SLA will be nice for your all around needs but may not give you every last possible HP out of the Nitrous. We're talking single digit HP loss here so personally I don't think I would worry with it.
Since your only going to occasionally use the spray I think the 112 would be good.
I am not an expert but this is my understanding after a talk with Dave at Combination Motorsports.
Old Jan 22, 2004 | 11:17 AM
rskrause's Avatar
Moderator
Nitrous has some similarities and some differences in terms of cam optimaization compared to a blower. The main function of overlap is to have the exhaust help scavenge the cylinder and pull in the fresh intake charge. A blower really doesn't need a lot of overlap because the intake is always under pressure. Nitrous is like NA from the point of view of cylinder filling. Overlap is needed.
Nitrous and a blower are similar in that they both substantially increase the volume of exhaust gasses. That is why optimal blower and nitrous cams will have a pretty big split between intake and exhaust duration. But in general terms, a good NA cam will work fine with a small to moderate nitrous shot.
Rich Krause
Old Jan 22, 2004 | 01:40 PM
Thanks for the input.
I'll add the 75-100 shot and we'll see what happens...
Larnach- sorry for the surprise- I forgot I had that there.
It's gone now...
Quickss96
Jan 29, 2016 05:56 PM
95chwagon
Oct 16, 2015 12:24 PM
95blkss
Sep 22, 2015 03:18 PM
95craz28
11
Sep 12, 2015 07:47 AM
Schul365
Aug 25, 2015 05:47 PM
