11 sec. on $5000 budget?
Old Sep 16, 2003 | 08:53 PM
jdizzell's Avatar
Is it possible to get my stock 95Z in the 11 with $5000 to spend on parts without using nos or a supercharger? That would include engine, tranny, rear-end and tires.
Old Sep 16, 2003 | 09:11 PM
funina91ss's Avatar
If your doing all the work yourslef yes .. get Heads&Cam Longtubes cat back and a stall. Unless you go big it will be close on the 11 sec. et
Old Sep 16, 2003 | 09:15 PM
Camaro_Maniac63's Avatar
Highly unlikely... Tires, rear-end and tranny would alone cost close to $3000-3500. And whatever you do to the engine/exhaust with the money left probably won't get you into 11s.
Old Sep 16, 2003 | 09:16 PM
gb95zconv's Avatar
If you do most of the work youself....yes
Long tubes and ypipe ....$700
Good ported heads......$1500
Big cam like cc306..........$250
ET streets......................$350
CAI...........$150
catback....$250
1.6 rr. and springs.......$350
A4 torque converter.....$700
Gears............................$500
Thats around $5000
Old Sep 16, 2003 | 09:48 PM
magius231's Avatar
try this one, close to my combination with all prices including misc. BS for install::
SLP 1 3/4 shortys - $500 (used)
XE 230/236 cam - $850 (w/1.6 RR, elec water pump, cmotorsports timing set)
heads - $1200
ET streets - $350
hooker/flowmaster catback - $250
dyno tune - $350
clutch (or converter) - $500
thats about $4000 right there and should be pretty close to 11's until you grenade the rear. I will come out below all this because I'm broke therefore I like to buy used stuff (brand new cam for $220, RR's for $100, headers for $250, etc)
Old Sep 16, 2003 | 10:18 PM
neil350's Avatar
Lighten it up
Fuel Pump & Regulator
TH350 w/ a 3600 Stall
Find a 12 Bolt
Find used suspension peaces like the torque arm, lcas
Find some used slicks and skinnies
Lot of Nitrous
Old Sep 16, 2003 | 10:40 PM
sbrown99TA's Avatar
Cam kit, nitrous, and a rear end. Expect the tranny to let go sometime, but for all of the other stuff you're well under that price.
Old Sep 16, 2003 | 11:19 PM
Rival's Avatar
Go with juice if you want to go 11's for 5k. It will be easier, so so much.
Old Sep 17, 2003 | 05:02 AM
magius231's Avatar
Originally posted by neil350
Lighten it up
Find a 12 Bolt
Lot of Nitrous
with all this stuff your still looking at $4000 and you now have a much less streetable car than before...why a TH350 of all things? I used to break those left and right with my 300hp 350...
Old Sep 17, 2003 | 07:09 AM
Fastbird93's Avatar
There's plenty of guys running around with stock heads into the 11's. The key to it is that they have a very well tuned in suspension. Concentrate your funds there, with a 12 bolt and the works, and save what you need for a cam, headers, and exhaust, and rockers. A cam like the 224/230, CC305, or even the 230/236 or CC306 would give you the power to accomplish this if you can translate that power to the ground. Can it be done for under $5000, yes. Is it going to be really easy?? No.
Old Sep 17, 2003 | 09:00 AM
1fast95Z's Avatar
Check out my sig. In the 11's having spent right around $3k. It can be easily done.
Old Sep 17, 2003 | 10:44 AM
CamaroBoy96Z28's Avatar
12-bolt, slicks, headers, cat-back, CAI, 175 shot. You're there for about $4k or so depending on if you find deals and dont go for high dollar cat-backs and other stuff you dont need to pay a premium for.
Formula Steve
Sep 19, 2023 08:31 AM
Ericksd
Jan 20, 2016 06:07 PM
MDZ28
Sep 7, 2015 09:16 PM
smoknta
Aug 27, 2015 05:07 PM
NewsBot
Aug 21, 2015 07:20 PM
