Summitt rebuild Kit?
Old Sep 16, 2003 | 12:13 PM
americanmusscle's Avatar
Anyone have any good things to say about the summitt all forged rebuild kit they have for 560 bucks or so? Is it a good kit to get or should I just save my money and go with somethin else?
Old Sep 16, 2003 | 12:19 PM
TMDZ28's Avatar
it's decent and strong, or so i've heard.
a nitrous expert once told me that it can handle 175 shot ot nitrous, so it should be pretty stong. but you need to buy the forged connecting rods and the forged crankshaft to go all strong...
Old Sep 16, 2003 | 12:38 PM
So thats how they get you. They make you buy a new crank and rods pretty smart.
Old Sep 16, 2003 | 12:53 PM
jkipp84's Avatar
I don't see how they're 'making' you buy anything beyond what the pkg has. If you planned on using it for nitrous, then if you'd gone with a different route (brand) of stuff, you'd have to buy it all anyway, yes?
If it's good quality, then I'd think it's a pretty good deal. Takes some of the guess work out as to what all you have to buy and what works with what.
Old Sep 16, 2003 | 01:10 PM
So your sayin i dont need to buy any other parts maybe?
Old Sep 16, 2003 | 01:43 PM
jkipp84's Avatar
Well, no not exactly - what is it you plan on doing with the car? Any nitrous/FI going on?
Also, what's the part number for that kit? I tried to find it.. no luck.
Old Sep 16, 2003 | 02:18 PM
Dont know the part # off hand but im just wanting a rebuit engine no nitrous in the future. I maybe looking at heads and cam with some headers.
Old Sep 16, 2003 | 03:09 PM
BlueCamaroZ28's Avatar
If you meant part# SUM-CSUM383KIT Chevrolet: 383 stroker kit, it is for 2-piece rear seal, not an LT1 engine.
Old Sep 16, 2003 | 03:17 PM
No its not that one. I think if you look in the catolog its like on the next page or the back of that page and it says something like LT1 year 93-97.
Old Sep 16, 2003 | 03:30 PM
KeVMaN's Avatar
yeah i've seen it too its in their catalog
Old Sep 16, 2003 | 03:34 PM
KeVMaN's Avatar
theres no part number for some reason, but
92-97 LT1 350/5.7L
Forged 10.4:1 $539.95
Hyperutectic 9.90:1 $449.95
Speed pro power forged pistons, piston rings, main, cam and rod bearings, high volume oil pump, fel pro gasket set, brass freeze plugs, plastigage and assemply lube. Available in standard bores and oversizes, compression ratios calculated with .030 over pistons
Old Sep 16, 2003 | 03:39 PM
92-97 LT1 350/5.7L
Yeah thats it!!!! Anyone have any info on how this rebuild package performs?
Old Sep 16, 2003 | 04:48 PM
ATMINF's Avatar
The forged kit is the one that I used for my rebuild. I also sent my blower back to ATI for new seals and bearings at the same time. I then slapped the motor all back together again. I reused the stock rods and crank (they checked out fine). So the rebuild was done on a budget and all total the whole thing cost me a little over $1800. That was done by me doing the rebuild and also included the cost of geting the heads freshed up and the block honed, and also getting the blower done by ATI. Back to the kit, for me I would say it is a good quality offering. I had NO issues with any of the parts that came with it, and would recommend the kit for buget rebuilds. I have about 2000 miles on the rebuild and the motor pulls strong and I have had no problems. Also my blower setup is a "low"boost setup running only 7-10 psi after the intercooler. Hope this helps, Good luck.
Old Sep 16, 2003 | 05:02 PM
1994TransAm's Avatar
thats me 2
hey guys,
i'm using the summit forged kit for the LT1 also.
it was cheap and a great deal.
i'm a 355 and i'm using stock rods and crank from a 22k mile motor. like th other guy said, everyting checked out fine.
i donno why i used forged pistons, i guess for safety?
i'm running lloyd elloit heads and xe 230/236.! judt did the compresion test last week.
Thanks for the info I might have to think about getting a rebuild kit for my car seeing that its got 115,xxx miles on the clock.
