11.8:1 compression too much?
Old Jul 23, 2004 | 08:15 AM
Gripenfelter's Avatar
I'm running 11.8:1 compression right now.
Last year it was 11.3:1.
Ever since I got my new heads I've been blowing the dipstick out a little bit when I floor it. I also have blue smoke from the exhaust when I floor it.
I ran 116mph traps like this.
Car seems to be getting quieter too. Its loud when I first start it up but then gets quieter.
Time for new rings? Too much compression?
Old Jul 23, 2004 | 08:17 AM
Fastbird93's Avatar
Re: 11.8:1 compression too much?
If the tune's good I wouldn't think it's too much. I'm running (trying to at least, damn rockers) 11.7 on my new 355 and it's seemingly fine.
Old Jul 23, 2004 | 08:22 AM
96z's Avatar
96z
Grip what is your dynamic compression ratio? How is your cooling system? Do a search in the advanced tech for dynamic compression ratio. You should be alright with 93 without a doubt IMO but firgure your dynamic out.
Old Jul 23, 2004 | 01:43 PM
llafro's Avatar
I'm running 11.8:1 on a stock bottom end. That's from heads shaved 0.030 and an LT1 Impala head gasket (0.029 compressed thickness). With the 230/236-112 cam, the dynamic compression comes out to about 8.9:1. I run it on 91 octane California MTBE gas (you can't get higher octane here without going to racing gas) with no problems. Knocks on wood :-)
If you are blowing out the dipstick, I'd say you have blowby problems and the engine might need some work. Blue smoke is also a bad sign, since it means you are burning oil. Run a compression check to see what's going on. On a cold engine, mine had 150-160 psi across the board.
BRAD
Old Jul 24, 2004 | 12:12 AM
Formula03's Avatar
Thats what I am running and I dont have any problems.
Old Jul 24, 2004 | 12:57 PM
When its cold its fine. When it heats up my oil pressure drops slightly and the car gets quieter.
I did also put in a bottle of engine oil supplement a month ago. I should do an oil change.
Old Jul 24, 2004 | 01:46 PM
darkangrydragon's Avatar
how old are your valve seals & springs? Are you getting any knock?
Old Jul 25, 2004 | 02:41 PM
Valves and springs are new.
No knock. No retard.
Quickss96
Jan 29, 2016 05:56 PM
surreybrad
Sep 29, 2015 09:00 PM
Daluchman1974
Sep 11, 2015 06:12 AM
13qtr
Jul 19, 2015 05:30 PM
pimpss96
Feb 12, 2015 01:28 PM
