is 11.5:1 to much compression for 91
Old Mar 21, 2005 | 01:51 PM
  #46
1racerdude's Avatar
Re: is 11.5:1 to much compression for 91
Originally Posted by kart90
You need it at seat?
I only have @ .020 and .050
@.020 its 286-296
only way to get it at 0 is to profile the cam that I know of
What's your CID,rod length,piston type and relief volume, 2 or 4 eyebrow,head CC's,piston in hole depth,and I will run it at .020 if that is there adv numbers.Give me the IVC point at .020 also and I will compare.
Old Mar 21, 2005 | 02:22 PM
  #47
Mystic97Z's Avatar
i am in a similar situation right now, building a 355. i want to get a real big cam (weekend car) and my cam guy is telling me i can easily run 11.5 to 1 or 11.8 to 1 on pump gas? i talked to combination motorsports, a speed shop, and my machine guy and they said u need to stay below 11 : 1 compression for pump gas, but at the same time, i KNOW people running up to 12:1 just fine on pump gas...but his car did blow up, lol. anyways, i'm stuck with buying a smaller cam to accomidate my 10.6:1 compression setup. i'd call a FEW machine shops and ask them, they build that sh it every day ya know. good luck.!
Old Mar 21, 2005 | 02:43 PM
  #48
SStrokerAce's Avatar
Larry,
You think you can run 11.5:1-12:1 on a 355 with a IVC of 74-75?
Obviously I don't know much about that.
Bret
Old Mar 21, 2005 | 02:49 PM
  #49
kart90's Avatar
SRP -5cc (2)
56cc heads
Felpro 1074 head gaskets(.039 thick)
block decked to 0.010
250/258@.050 109LSA put in at 108 centerline
bore 0.040
stoke 3.75
Rods 6"
No IVC numbers with me
Old Mar 21, 2005 | 05:59 PM
  #50
kart90's Avatar
Ttt
Old Mar 21, 2005 | 07:40 PM
  #51
1racerdude's Avatar
SRP -5cc (2)
56cc heads
bore 0.040
stoke 3.75
Rods 6"
Your static is 11.958
Your dynamic is 9.046
That is the max with 92 octane.Ya gonna need a good tune and cooling to run this on the street or 110 VP fuel.
Old Mar 21, 2005 | 09:42 PM
  #52
kart90's Avatar
Wow So What Would It Be With 0.029 Impala Gaskets?
Old Mar 21, 2005 | 10:15 PM
  #53
1racerdude's Avatar
Static is 12.300
Dynamic is 9.297
This is with a .029 gasket.The Impala gasket is less than .029.
Old Mar 21, 2005 | 10:23 PM
  #54
kart90's Avatar
Thank you
Old Mar 21, 2005 | 11:15 PM
  #55
Zigroid's Avatar
what do you mean by good cooling? stock not up to the task?
Old Mar 22, 2005 | 01:39 AM
  #56
1racerdude's Avatar
Not with that high of a DCR.
Old Mar 22, 2005 | 01:40 AM
  #57
1racerdude's Avatar
Thank you
You are welcome.
Old Mar 22, 2005 | 10:23 AM
  #58
kart90's Avatar
What are the limits on DC for good cooling ? Evans coolant would help?
Old Mar 22, 2005 | 10:30 AM
  #59
1racerdude's Avatar
What are the limits on DC for good cooling ? Evans coolant help help?
9.0 and if you are brave and the motor is built for it then 9.5 is the max on 92 octane. Don't go that high if you have not designed the engine for it or it will rattle its *** off and you will have to pull so much timing it won't run.
This is with a LARGE radiator, Evans and all the tricks pulled out of the hat.
Old Mar 22, 2005 | 04:09 PM
  #60
Deenasty's Avatar
Damn, $20 for every person that wants to know from now on!!! J/K
1racerdude do mine doing mine also?
CID: 383
Rod Length: 6.00"
Piston Type: SRP -16cc
Head: 54cc
ADV DUR on Cam: 290/290 (ABDC 48.6)
Stock Head Gaskets: 0.49?
thanks a million!
