is 11.5:1 to much compression for 91
Old Feb 12, 2005 | 10:35 PM
  #31
Capt'n Two Rotors's Avatar
Re: is 11.5:1 to much compression for 91
yes it is completely stock, I'm sorry I can't give you the exact figures cuz its driving around right now.
Old Feb 13, 2005 | 11:15 AM
  #32
1racerdude's Avatar
I pretty much know the stock measurements but I can't even guess at the adv duration of your cam and I don't like to guess on this.
It will more than likely be fine with a .039 Fel Pro gasket.A .022 might be OK also but all that is a guess.
Old Feb 13, 2005 | 11:53 AM
  #33
ok thanks I'll try and find the adv durantion today if I can.
Old Feb 14, 2005 | 02:05 AM
  #34
I tried but can't seem to find the adv duration anywhere for this cam maybe I'll call crane on monday, thanks for your help
Old Mar 20, 2005 | 09:45 PM
  #35
SILVERZZ28's Avatar
What program are you using larry
Old Mar 20, 2005 | 09:50 PM
  #36
1racerdude's Avatar
Performance Trends
Old Mar 20, 2005 | 10:04 PM
  #37
fireman's Avatar
Originally Posted by 1racerdude
Your DCR is probably more than 9.0.
I'm not really sure, maybe you could tell me?
SRP -5cc, .020 overbore
stock heads w/ 1.98/1.56 raceflos
Felpro 1074 head gaskets(.039 thick I believe)
block decked to 0
CC306 cam with 1.6 rockers
I come up with 11.8:1 static compression ratio, not sure if thats right.
Old Mar 20, 2005 | 10:17 PM
  #38
1racerdude's Avatar
Give me your advertised duration on the cam and I will figure it for you.Can't do on either of my programs without advertised duration, not @50.
Old Mar 20, 2005 | 10:22 PM
  #39
SILVERZZ28's Avatar
306 is 230/244 on a 112 .
Just add .050 to the numbers
Old Mar 20, 2005 | 10:25 PM
  #40
fireman's Avatar
sounds right to me.
Heres the spec sheet on the cam:
http://www.compcams.com/Technical/Se...umber=07-306-8
Not sure if that helps or not.
Thank you
Old Mar 20, 2005 | 10:35 PM
  #41
kart90's Avatar
Could you do mine also?
SRP -5cc
Felpro 1074 head gaskets(.039 thick)
block decked to 0.010
250/258@.050 109LSA put in at 108 centerline
bore 0.040
stoke 3.75
Old Mar 21, 2005 | 02:04 AM
  #42
1racerdude's Avatar
NOT.
Old Mar 21, 2005 | 02:16 AM
  #43
1racerdude's Avatar
block decked to 0
Your static is 11.794
Your dynamic is 8.750
This is with 54CC chambers as in a stock head,stock stroke,and flattop pistons with 5CC relief's,5.7 rod.
Old Mar 21, 2005 | 02:19 AM
  #44
1racerdude's Avatar
SRP -5cc
bore 0.040
stoke 3.75
Give me the advertised duration numbers on your cam and I will run the numbers.Not @50 numbers.
Old Mar 21, 2005 | 01:28 PM
  #45
kart90's Avatar
You need it at seat?
I only have @ .020 and .050
@.020 its 286-296
only way to get it at 0 is to profile the cam that I know of
