11.5:1 + 91octane =?
Old Mar 15, 2007 | 10:54 AM
  #46
SS MPSTR's Avatar
Originally Posted by Colin91Z
I ended up not using cometics...but the part # that I was going to use was C5645-036. Those are 4.04 bore, .036 thick. Those work if you have stock castings with 2.00/1.57s, but if you have large valve heads you would need the 4.100 bore gaskets which are C5646-036
The reasons that I didn't use them is because later I measured and found that my pistons were all .005-.006 in the hole, and also that the finish on the deck surface of my block was not smooth enough for cometics to seal properly. So I went with GM Impala SS gaskets which gave me the same CR with a .034 quech.
Thanks for the information.
Old Mar 15, 2007 | 02:12 PM
  #47
Colin91Z's Avatar
No prob
Will84
Jan 4, 2007 06:25 AM
mrz28 73/97
Advanced Tech
Feb 7, 2005 09:04 AM
texasTA
Advanced Tech
18
Jan 20, 2005 12:06 AM
zhevy-1
Advanced Tech
Apr 1, 2003 08:53 AM
Capn Pete
Classic Engine Tech
15
Aug 26, 2002 10:22 PM
