11.5:1 + 91octane =?
Will it work on my lt1 without causing problems or robbing me of power. Can I get by on 91 as a daily driver and just add some octane booster when I plan to run it hard? I'd appreciate your input.
Our premium here in new mexico is 91 due to altitude. It should be higher at lower altitudes, like oakland. Don't you have 93 out there? I'd run the 93 out there. But, if you can scan it for knock, then you can always pump in some 91, scan it, and if it's not pulling any timing due to knock, then your good to go.
Ken R.
Ken R.
it wwould have been 11.78:1 but we went with a thicker gasket for a bit of breathing room. Im hopin for the best its done I just need rockers now.
A lot depends on the cam, heads, and operating conditions. If Lloyd said his combo will work on 91, I'd take his opinion as more credible than someone just guessing. I will say that ageressive timing retard, while it will protect the motor, really kills performance. I disabled the KR on mine long ago and never looked back. However, I have verified the lack of knock and I am careful how mine is operated.
Rich
Rich
Go with the Gasket lloyd says to use, your heads flow will be altered by the thicker gasket as well as losing quench. You want piston to head clearance of ~0.31. If your clearance is there and your static compression is under 12:1 you're good to go.
Which is why a good engine builder is worth his weight in gold. Your engine and tune must have been spot on, Your engine builder might have been able to fix the knock below 2k with a little prep work on small thing like the spark plugs or maybe a slightly different cam profile. But with a 13:1 motor I'm assuming this car didn't spend much time bellow 2k anyway
