11.48 ET on second hand LE2s
Old Apr 27, 2008 | 12:03 PM
  #16
reamo04's Avatar
nice. Before i decided to go turbo, i was going to run that cam, or the lunati 60123. Looks like a lot of people have good luck with the XFI cams.
Old Apr 27, 2008 | 12:47 PM
  #17
Greaseymec's Avatar
I,ve seen a few posts where a few said it might make a better door stop than a cam shaft. If its doing good for me with LE2 heads and just a base tune, think of the potential!
Mec
Old Apr 27, 2008 | 03:29 PM
  #18
RedLT4Mike's Avatar
Shooting for that good dynamic CR really paid off.
Congrats on placing at the shootout. From what I've read
you had a hell of a time.
I wonder what a set of comp 977 springs would do for controlling
that cam in the upper rpm's?
Old May 4, 2008 | 07:18 PM
  #19
kline454's Avatar
just went 11.65 @ 117.5 on le2 BRE cam...mail order tune full weight car.
Old May 4, 2008 | 07:39 PM
  #20
Greaseymec's Avatar
Great Run!!!
Mec
Old May 4, 2008 | 07:50 PM
  #21
MEAN LT1's Avatar
Sounds like youve got a good combination of parts going on. Very nicetime and 60'. Lets hope this thread stays on track.
Old May 5, 2008 | 08:16 AM
  #22
Colin91Z's Avatar
Nice runs Mec, glad I was there to witness them
After your opti problems at the hotel, I thought that you deserved one of those opti trophys
You placed better than I did in the N/A class, I was paired up with Brady (roadtrip120) in the first round...so needless to say I didn't make it to the second round
At least I ran a new best time though
See ya next year!
Old May 6, 2008 | 01:33 PM
  #23
The Engineer's Avatar
Mec,
Good runs with your new package and the XFI-292 cam. I get upset when people bad-mouth my XFI cam here on the forum, however, none of them have ever out-run me.
Here are some times from my last time out (2 weeks ago). Track was margional w/ poor 60fts (typically I have 1.50s) and the DA was around 2870.
Also, I'm looking forward to next year's shoot-out and I plan to show-up with a few new upgrages next year.
WD
Old May 6, 2008 | 01:36 PM
  #24
383racecar's Avatar
there is a ltx event coming up.
jakesz28's Avatar
Calling Out all 2nd generation LTx's
I have rented the track at Cordova IL on Sept 7 2008. I will be organizing a LTx event similiar to the LTx Shoutout. I would like to bring in as many LTx powered cars as I can. The payouts are yet to be determined. The rules brake down like this.
LTx showdown rules
SHOWDOWN rules
Classes, Rules & Payouts
Classes and rules are subject to change.
Payouts are TBD on event participation.
LTX Outlaw
• Run what you brung HEADS UP format
• Limited to quickest 16 qualifiers
Must have LT1 based engine. If heads do not retain factory 23° valve angle, a 150 lb. weight penalty will be enforced. Converted intakes, sheet metal, or stock intakes allowed. Multiple power adders allowed. 10.5 tire max (W’s limited to 29.5). Drag radials permitted any size. Stock style suspension preferred. If you have a 4-link or similar setup a 150 lb weight penalty will be enforced. Mini tubbing allowed. Wheelie bars allowed. No back half cars. Mufflers are an option. Any carburetor allowed. Any EFI system allowed. Any OEM style transmission allowed. If Non-OEM style transmission, a 100lb weight penalty will be enforced. Lexan permitted. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Weight 2800 nitrous 3300 forced induction.
Class Sponsors:
Estimated payout: TBD by participation
LTX Drag radial (Power Adder)
• Limited to quickest 32 qualifiers
Must have LT1 based engine. Heads must retain the factory 23° valve angle. Converted intakes, sheet metal, or stock intakes allowed. Single power adders only. Nitrous must be single stage. Supercharger FIA,YSI max. Turbo limited to 81mm. Twin turbo setups must send details of setup to the organizer for decision. Drag radials permitted any size. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any EFI system allowed. Any one piece carb allowed. Any OEM style transmission allowed. Must have factory glass (no Lexan…etc). Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Nitrous only cars get 300 lb weight break off the minimum. Minimum weight limit 3200 lbs.
Class Sponsors:
LTX Heads up N/A (Naturally Aspirated)
Must have LT1 based engine. Heads must retain the factory 23° valve angle. Converted intakes, sheet metal, or stock intakes allowed. No power adders allowed! 10.5 X 29.5 tire max. Drag radials permitted. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any carburetor allowed. Any EFI system allowed. Any OEM style transmission allowed. Must have factory glass (no Lexan…etc). Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Minimum weight limit 3200 lbs.
Class Sponsors:
LTX Heads up 6-speed
Must have LT1 based engine. Heads must retain the factory 23° valve angle. Single stage power adders allowed. Aftermarket intakes allowed with a 100lb weight penalty. Stock PCM only (Aftermarket EFI 50lb weight penalty). 10.5 X 29.5 tire max . Drag radials permitted any size. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any carburetor allowed. Any OEM manual style transmission allowed. Must have factory glass (no Lexan…etc). Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Minimum weight limit 3200 lbs.
Class Sponsors:
LTX Extreme Street
Must have LT1 based engine. Heads must retain the factory 23° valve angle (no converted SBC heads). Only stock/stock style ported intakes allowed (welded intakes not permitted). Single stage power adders allowed. Stock PCM only (no aftermarket EFI). Opti-spark distributors only no rear mount allowed. Coil per plug allowed. DOT tire only. Maximum size 28" X 10.5" (actual tread with). Only exception will be 315/35-17 drag radials, 325/50R15 allowed, dr limited to 28”. Must have stock style suspension, 4 links or ladder bars not allowed. Wheelie bars not allowed. No back half cars. Must have mufflers. Any OEM transmission allowed. Must have factory glass (no Lexan…etc). Must have working lights, wipers, and horn. Must have current tags. Interior must be original appearing, headliner, dash. Front seats, rears can be removed. Car and driver must meet NHRA/IHRA certification requirements for the times the car is running. Minimum weight limit 3400 lbs.
Class Sponsors:
LTX Bracket - 12.49 & Faster
• No limit in entries
Must have LT1 based engine. Transbrakes allowed. NO electronics ( delay boxes, throttle stops..etc). Car and driver must meet NHRA/IHRA certification requirements for the times the car is running.
Class Sponsors:
LTX Bracket - 12.50 & Slower
Must have LT1 based engine. NO electronics (transbrakes, delay boxes, throttle stops..etc). Car and driver must meet NHRA/IHRA certification requirements for the times the car is running.
Class Sponsors:
We are currently going to work on getting some sponsors to help with the payouts.
Old May 6, 2008 | 01:38 PM
  #25
383racecar's Avatar
i will be in the Extreme Street class i just went 10.29@133 on a 383 untuned le2 headed BRE cam camaro full weight that meets all the Extreme Street rules.
Old May 6, 2008 | 05:54 PM
  #26
Greaseymec's Avatar
See ya next year!
Congrats on the new PB! 11.48 is my new PB also. I will be trying to improve on it though. (car has lots more in it) Dont worry, Brady put me on the trailer also. I would have made it a better race if I had cut a better light. (I was dead late on the tree. The starter almost had to blow a hand held air horn to let me know the light was green!!lol) Next year will be interesting. Everyone will be using the 08 event as a measuring stick. I expect next years heads up classes to be much tougher! Hope the moons align for everyone to make it back next year!
Originally Posted by The Engineer
Mec,
WD
All I know Warren is that when I lined up next to you on a warm up run, the only thing I saw was the back end of your car from the tree to the stripe!! I'm gonna be working hard to try and match those times of yours so maybe next year it will be you and me in the final!
Mec
Old May 8, 2008 | 04:27 PM
  #27
Formula408's Avatar
Hey Mec,
Don't know if you remember me I was the green formula that lost to you when my throttle cable broke at LTx. It was good to see someone there having as much fun as you. I've gotten mine down to 11.21 @ 124.55 I should be in the 10s with that mph but cant seem to get out of the gate.
Hope to see you there next year with a 10 sec 408!
Old May 8, 2008 | 04:35 PM
  #28
Colin91Z's Avatar
Originally Posted by Formula408
Hey Mec,
I think I ran against you in qualifying, what does your car look like? Was it the green formula that was parked next to me in the pits?
This is what my car looked like at the shootout btw...
Old May 8, 2008 | 06:07 PM
  #29
Formula408's Avatar
[quote]I think I ran against you in qualifying, what does your car look like? Was it the green formula that was parked next to me in the pits?[quote]
Ya, I think I was parked by you. I was the guy with the goofy exhaust that hung real low cuz of my bmr crossbrace (which btw is fixed now and looks much better) .
I'm only running 31 degrees of timing right now can't wait to get it up to 35 or so...
Old May 8, 2008 | 07:43 PM
  #30
[QUOTE=Formula408;5360843][quote]I think I ran against you in qualifying, what does your car look like? Was it the green formula that was parked next to me in the pits?
I remember my son, Shawn and I were talking with you (and some othe guy) while we were waiting in-line to get into KCIR on Saturday morning. I think we were wiping my car down in hopes it would quit raining.
Nice meeting you there!
WD
