11.41@118.49 Na Lt1
Old Jun 3, 2007 | 08:52 PM
  #16
mattbailey's Avatar
Originally Posted by nick3
i am shifting at 7000 rpms and have no problems with the gm opti. only the accel. it really sounds like the same problem i was having.
That is good to know. I'm leaning toward that, it seems to fit my slim/none budget for the car right now.
Old Jun 3, 2007 | 09:47 PM
  #17
reamo04's Avatar
just curious, what are the specs of that cam?
Old Jun 3, 2007 | 10:00 PM
  #18
mattbailey's Avatar
It is what used to come from the LE2 package when Joe O speced the cams. The duration is close to a GM 847.
Old Jun 3, 2007 | 10:56 PM
  #19
Javier97Z28's Avatar
Moderator
Originally Posted by ABA383
Nice times/mph...I've never had an opti explode and I've been using the actual GM opti...But I'm not at your rpm either...Again congrats!!!
--Alan
My OEM GM opti blew up in the waterbox during a burnout at about 6200 RPM with my cc503
Rotor just fell apart inside.
Nice times and MPH man, looks like our cars would be a real close run.
Old Jun 3, 2007 | 11:46 PM
  #20
There's a lot to be said for using one of the aftermarket ignition systems that allows you to run without the rotor.
Old Jun 4, 2007 | 01:17 PM
  #21
ABA383's Avatar
Originally Posted by mattbailey
Thanks Alan, where do you shift your cam at? I don't know what is causing the rotor bolts to come out, even after loctite was added.
I (the computer) shift at 6300 rpm...I guess its hit or miss with optis...I replaced my original opti with another GM one about 4 years ago as routine maintenance...
--Alan
Old Jun 4, 2007 | 01:47 PM
  #22
LT4POWR's Avatar
nice run
Old Jun 4, 2007 | 02:42 PM
  #23
The Engineer's Avatar
the way ur car is going - it will, thats why I got a MSD
I have a relatively new GM Opti (two seasons of bracket racing only), but I think it is starting to go out due the RPM I’ve been turning (6500+). I have a random high RPM miss that has to be ignition related. Everything else is new (coil, ICM, plugs, plug wires) and the random miss seems to be getting worse with time, therefore I suspect the Opti.
I have one of the MSD Pro-Billet distributors on order now. I heard of some problems with the early MSD Pro-Billets, so I hope they have everything worked-out now.
WD
Old Jun 4, 2007 | 04:23 PM
  #24
speed_demon24's Avatar
WD
I know I don't have their whole opti, but I put an msd cap/rotor on my car a month or 2 ago and it seems to be holding up fine. I took all the screws out and put red loc-tight on them for insruance.
Old Jun 4, 2007 | 08:07 PM
  #25
mattbailey's Avatar
Fred, what setup do you run?
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
