100 octane?
u could but it won't help you any. Its also possible you will loose performance. The higher the octane the slower it burns (something to taht effect). It would be better for a high compression engine or if your running some sort of boost where you can detonate if you run too low octane.
Won't help, won't hurt anything, and it doesn't "burn slower" (a popular misconception - but octane does not correlate to burn speed).
You would just be wasting your money. I'm running close to 11:1 on a 7,000+rpm solid roller motor, and normally aspirated HP peaked (as measure with numerous tuning pulls on an engine dyno) with 94-octane fuel. Moving up to 100-octane did not allow any additional timing, nor provide any benefit for any significant changes in A/F ratio, along with timing changes..... Which is what you would need to do to see any more power.
Run your car with a scanner, and look for knock retard. Use only the octane level that allows you to run with no knock retard. Anything above that level is a waste of money.
If you want to do some good, just go buy a gallon of xylene, and put that in, and then 3-4 gallons of gas. should get you to 94-95 or so octane, and it will clean out your fuel system nicely
Anything less than 30% xylene wont do any kind of harm to your fuel system
Well I can atest to the fact that it won't hurt or help, here in japan on the military base all they offer is 99.5(at a 1.63/gal
and it is all my car has seen for 50k miles. Can't wait for my procharger to get here though, the 99.5 will help then!
)and it is all my car has seen for 50k miles. Can't wait for my procharger to get here though, the 99.5 will help then!
RUENUF
Mar 13, 2016 03:37 PM
Aug 24, 2015 06:41 AM
