10.92/ 126.95 Finally
Old Oct 4, 2008 | 05:58 AM
jonesy's Avatar
finally broke into the 10's
forged 350, self ported LT1 heads, GM 847 cam, 37 lb racetronix, 58 mm,hooker long tubes, magna flow ex.,3.90 9" , M 6,175 shot, Spohn torgue arm, QA1's front , AGX rear,ET streets 11.50 -15
theres more left in her, my 4 th time to track with only 2-3 passes a night, car was running strong with the cool night air, but track official booted me for not having a cage, hope to break 10.50's once cage is in, getting alot of body flex even with the subframe connectors
1.56 - 60ft.
Old Oct 4, 2008 | 06:01 AM
jonesy's Avatar
3670 raceweight
Old Oct 4, 2008 | 06:20 AM
You don't need a "cage" to run in the 10's, at least not in NHRA, only a 5-point roll bar. Certified cage is required below 10.00.
Old Oct 4, 2008 | 06:30 AM
jonesy's Avatar
@ the tracks up here, anything faster than 11.50 need a 6 point what the tech official said last night
Old Oct 4, 2008 | 06:35 AM
A "6 point" is still not a "cage", its a roll bar.
Old Oct 4, 2008 | 08:50 AM
slowride94z's Avatar
great runs , glad to hear about the self ported heads
pictures or vid?
Old Oct 4, 2008 | 09:41 AM
MichiganSkip's Avatar
Where you running at? You're only about 30 minutes from me.If you run OC I've probably seen your car. What color is it and next time, I'll swing over and say hi.
Hey were you at OC last night with a black 4th gen with little cowl hood? If so I did say hi as I walked right past ya. If that was you, you row those gears pretty good
Skip
Old Oct 4, 2008 | 11:12 AM
jonesy's Avatar
EXCUUUUUSE ME! ROLL BAR!! bar/ cage, who cares, doesn't matter still got booted for not having either one, and excuse me for mistyping torque arm aswell
Old Oct 4, 2008 | 12:03 PM
Z-RATED94's Avatar
Who cares, you will when you see the difference in price. That and a few other things to run lower than 11.50.
Old Oct 4, 2008 | 02:34 PM
Just trying to save you a $1000 or more.
It was not my intent to pi$$ you off. I'll butt out
Old Oct 4, 2008 | 08:02 PM
94zgreenmachine's Avatar
IF, you can TIG weld, you can get a 10 point from Spohn or S&W racecars for $599 and those are the chromoly cages. The 6 point is about 1/2 of that but if you get Chromoly, you WILL need to TIG weld it.
I recently tore my dash out to delete my A/C. It was not fun, especially doing it by myself. The 6 point won't go thru the dash but the 10 point will. Good luck!! and nice time runs
Old Oct 4, 2008 | 10:15 PM
jonesy's Avatar
Lane Automotive sells a mild steel one for around 200.00 ( 6pt)weighs 20lbs more than chrome moly
magman
Apr 15, 2016 03:08 AM
PopoFormula
Oct 12, 2015 04:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Ks0209
Oct 1, 2015 07:32 AM
kandied91z
Sep 30, 2015 11:43 PM
