10.847 @ 126.08 staight off the trailer first pass of the year
Old Sep 6, 2008 | 06:38 PM
  #16
jakesz28's Avatar
I would say your going to want 1 7/8 headers or at least a 1 3/4 stepped to 1 7/8.
Old Sep 6, 2008 | 09:38 PM
  #17
Nostang 96z's Avatar
Thanks for the advice! Keep us updated when you dial the car in.
Old Sep 7, 2008 | 08:04 AM
  #18
tomcowle's Avatar
I'd use the smaller tubed headers, many cars are "over-header'd". the smaller header will not be such a performance killer as an over-header'd engine will be. I know of many Stock eliminator f-bodies that are running mid 10's and better with 1 5/8" to 1 3/4" primary tubed headers.
Old Sep 7, 2008 | 09:32 AM
  #19
mdacton's Avatar
Glad you got it together jake.
Old Sep 7, 2008 | 11:50 AM
  #20
SS MPSTR's Avatar
Originally Posted by Nostang 96z
Thanks for the reply/info!
The 383 I am building is 11.8-1 comp, diamond nitrous pistons, Lunati pro mod rods, Eagle forged crank, 4 bolt splayed caps, solid roller Joe O grind 258 268 .635 lift with 1.6's 106lsa, endura x lifters, Eric Bradby ported AFR 220 heads (flow well over 300cfm), T&D shaft mount rockers, Accel single plane intake, with a 1200cfm tb (carb style). I hope to make 600 N/A at the crank and ~850-900 crank on a 250 hit. My goals are to go at least 1 sec faster than my previous combo N/A and on the bottle.
thanks again,
Matt
Are you using FAST or similar? Sounds like a killer combination.
Old Sep 7, 2008 | 11:53 AM
  #21
SS MPSTR's Avatar
Originally Posted by jakesz28
Whats wrong with that? I have nothing agaist the opti or fuel injection but this motor will be going to 8000rpm's when I feel good with the tune. I was shifting at 7500 last night. Are you willing to do that with the stock ecm? After spending what I spent this year the carb was a cheaper way to go.
Easy. I said I was trying to understand. Obviously, for anything over 7100, the factory pcm isn't going to cut it. Are there any plans to return to fuel injection, or will you stay with the carb?
Old Sep 7, 2008 | 12:19 PM
  #22
flyinZ's Avatar
Glad to see you got it running and down the track, Mike.
Nostang, you have a PM.
Old Sep 7, 2008 | 02:47 PM
  #23
Leaning towards Gen 7 DFI as it looks the most user friendly. I will engine dyno it with a carb when it is completed probably sometime in Oct.
Old Sep 7, 2008 | 02:51 PM
  #24
jakesz28's Avatar
I have a brodix HVH set up for fuel injection but fogger placement is going to be a issue.
I sold the 39lb injectors that were in it I need a 45-50lb injector and the fast ecm's are a little pricy. I was going to do a dart block because of the times I want to run but then the LTx Shootout got going last year so I stuck with the LTx block, didn't have the money to mess with the fuel injection before the shoot out so a friend said I could use his carb. Ordered an intake and still wasn't ready for the shoot out. I should be there next year.
Yes it's about time. I'm happy so far just wish I would have got a full pass on the 100shot. But almost lost the hood. I did away with the factory latch and only put in two hood pins. The new starter went out a week after I got it, so I was afraid to shut it off in the lanes I guess the one pin just vibrated out. When the drivers side of the hood lifted about a foot in the air I got a little scared and hit the brakes before the 1/8. Still went 10.9
Old Sep 7, 2008 | 03:28 PM
  #25
jakesz28's Avatar
thanks again,
Matt
Did you go with a 6" rod or a 5.85" ? I thought I was going to need the shorter rod but LME wanted to benefits of a 6" rod and said the pistons will still have enough material above the top ring. I would have liked to see the piston they stuck in here. Because with the deep valve reliefs I'm a little worried about pushing it.
Old Sep 7, 2008 | 05:56 PM
  #26
I went with a 6" for the same reasons. There looks to be plenty of meat left on the pistons for the 250 shot I plan on running. my valve reliefs were only 3.4cc's as I needed to keep them small to reach my desired compression in a flat top piston. Yours are probably very similar to mine. I have some pics I can send you if you would like a look.
Old Sep 7, 2008 | 06:33 PM
  #27
jakesz28's Avatar
I wouldn't mind seeing them. I know the valve reliefs are fairly deep on mine. The cam is over .700 lift roughly 270 280 duration.
My email is smzjacobs@iowatelecom.net
Old Sep 8, 2008 | 12:46 AM
  #28
JD311's Avatar
thanks again,
Matt
That cam sounds more like a N/A cam 106 lsa is very tight. I would widen it up a bit for spray. A 250 shot is not major but a wider lsa would be better in a nitrous motor. That is if you are going to use it as a mostly N20 motor. We used a fogger on a 106 cam and it blows alot of that right out the exhaust. Picked up with a wider lsa.
Old Sep 8, 2008 | 05:59 AM
  #29
Yeah it is def more of an NA cam. I will run it NA 95% of the time as this is more of a street car. I don't mind sacrificing 20-30hp on the bottle for a little more NA. BTW, how much did you lose NA with the nitrous specific cam and how much more did you gain?
Old Sep 9, 2008 | 02:29 AM
  #30
JD311's Avatar
couple tenths. we changed converters right before the cam change, it helped the 106 cam and really woke up after the new cam install. I think it was running like 6.10 in the 1/8 with old cam to like 5.80s after cam change. Was less violent as well. That was in a car we used to run, heads only flowed 270 lol. Have learned alot about spray since then, we didnt even flow the fogger back then
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
armedtrigger
Feb 24, 2015 08:30 PM
NewsBot
Jan 23, 2015 01:10 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
