10.6 At 129 Still Has More....
Old Apr 17, 2007 | 10:47 PM
red96z's Avatar
STOCK BOTTOM END HEADS AND CAM AI STUFF AND A NX WET KIT ! CUT A 1.6 SIXTY AND GOT OUT OF IT NEAR THE END CAUSE IT WAS CROSSING LANES . FIX THE SIXTY AND DRIVE LOW LOW LOW LOW 10ssssss. HELL YA NEEDS TO HOOK AND ITS ON JUST THOUGHT I WOULD SHARE. THANKS
Old Apr 17, 2007 | 10:49 PM
2000GTP's Avatar
Do you have any rough specs on your heads and cam setup? What about your nitrous setup, what size shot were you spraying? What kind of tires were you using during the runs?
Old Apr 17, 2007 | 11:33 PM
red96z's Avatar
[QUOTE=2000GTP;4548668]Do you have any rough specs on your heads and cam setup? What about your nitrous setup, what size shot were you spraying? What kind of tires were you using during the runs?[/QUcam is a custom grind from AI and the heads are LT1 stock ported castings by AI. wet 175 real rich though... tires 325 50 15 mickey drag radials . btw that was the only run cause i have no cage and they flaged me it has more just didnt get a chance to see tonight so.... will order cage and drag bar tomorrow and get those 60 ft times to 1.4s and here comes some 10.30s or better.
Old Apr 18, 2007 | 07:33 AM
CrazyLT1's Avatar
wow man those are some nice times!
Your only problem is that: heads/cam + 175 shot = BOOM!
But it will be fun till that happens
You already have the 12 bolt - why didnt you build the bottom end while you were at it?
Old Apr 18, 2007 | 07:53 AM
2000GTP's Avatar
Yeah, you are probably using borrowed time with that stock bottom end.
Old Apr 18, 2007 | 08:09 AM
LT4POWR's Avatar
Your car might have more in it, but your bottom end doesn't, sorry. Nice time nonetheless.
Old Apr 18, 2007 | 08:12 AM
Z-RATED94's Avatar
Nice times, but what does it run in the quarter? .............................J/K
Old Apr 18, 2007 | 08:33 AM
Denny McLain's Avatar
That's funny!!
Old Apr 18, 2007 | 09:04 AM
Gripenfelter's Avatar
A friend of mine ran a 150 shot with a heads and cam motor with a stock bottom end for YEARS. Depends on your tuning. He took all the precautions and the car is still alive today.
Forged pistons basically give you more margin for error in the tuning. But you are pusing the envelope on what the stock bottom end can handle.
Old Apr 18, 2007 | 10:06 AM
MEAN LT1's Avatar
Exactly.
Old Apr 18, 2007 | 10:10 AM
RealQuick's Avatar
Great results.
Old Apr 18, 2007 | 10:17 AM
danhr's Avatar
congrats on the times and finding the caps lock button
Old Apr 18, 2007 | 10:25 AM
tireburnin's Avatar
Congrats on the new best. What was the break down for the 8th and such?
And as for the 1/4 mile joke, if that car ran 10.6 at 129 in the 8th, that would be one hell of a fast (mph car).
Old Apr 18, 2007 | 10:26 AM
neil350's Avatar
Grip got it right, tunning is the big thing. Theres been LS1s in the 9.6s on stock short block, both local cars, lot of tunning. Theres also an LT1 in the 9s with the stock short block. Lot of it has to be keeping it from detonating, having enough fuel and then not over reving the motor on spray with the stock rods.
Old Apr 18, 2007 | 10:35 AM
SS MPSTR's Avatar
Nice times.
