1.7 rrs
Old Apr 18, 2006 | 02:28 PM
19camaro71's Avatar
1.7 rrs
I have tried the search and have come up with a few different answers. My next mod will be valvetrain and i think i just want to do roller rockers. I have read about the 1.7 ratio and i just want to know what all is involved in putting them on as opposed to doing 1.6. Do springs need to be replaced, if so which ones will work? Do i need new pushrods/locks/seats/guide plates? Any information will be awesome. Thanks
Rob
Old Apr 18, 2006 | 02:38 PM
Stoopalini's Avatar
Re: 1.7 rrs
Here is what I used to install mine: (original post is here)
  • Scorpion Rockers SCP1026 http://www.flatlanderracing.com
  • Comp Cams Hardened Pushrods p/n 7939-16
  • Comp Cams 918 Springs 26918-16 CompCams
  • 10* Comp Cams Steel retainers p/n 759-16
  • 10* Comp Cams Super Locks p/n 611-16
  • GM Valve Seals 10212810 & 12564582 http://www.gmpartsdirect.com
  • GM Guideplates 14011051 http://www.gmpartsdirect.com (these needed modification)
  • ARP 7/16 Studs 134-7103
  • Comp Cams Shim Kit p/n# 7453
  • Engine Assembly Lube
  • Locktite
So in short, yes you will need to replace springs, locks, retainers, pushrods, and use guideplates (I also had to replace lifters because one of them failed from the added stress of the 1.7s).
Thomas.
Old Apr 26, 2006 | 02:22 PM
19camaro71's Avatar
Re: 1.7 rrs
Thanks a lot for this, i will be planning on doing this this summer.
I have two questions though...
1) Does this require any specific tuning (as opposed to just ordering a chip(my car is a 1993))?
2) How or where do I buy these LT4 valve covers/accessories from?
Old Apr 26, 2006 | 03:58 PM
Stoopalini's Avatar
Re: 1.7 rrs
No specific tuning is required. It ran fine with a stock tune, and even better with MadZ28's tune.
I bought the LT4 valve covers from Jason Cromer. His contact info can be found on Shoebox's Website.
Thomas.
KYWes
Jun 14, 2022 06:52 AM
Cam's maro
Aug 11, 2015 07:45 AM
MadMav
Jun 15, 2015 09:51 PM
sideways_Into_3rd
Advanced Tech
Apr 7, 2003 07:33 PM
xxsaint69x
Mar 9, 2003 10:32 PM
