1.6rr's and 1.5rr's?
Old Feb 24, 2007 | 07:20 PM
Mauiguyy911's Avatar
Ok, just out of curiosity, whats the difference between going with a complete set of 1.6rr's as compared to a split of (8)1.5's and (8)1.6rr's? Does it depend on application and which is better for more power?
Old Feb 24, 2007 | 08:16 PM
PoorMan's Avatar
I read a article in Hot Rod that showed that putting 1.5 on the intake and 1.6 on the exhaust actually made more hp on a nitrous motor than 1.6 on both.
I do not remember all the engine specs.
Old Feb 24, 2007 | 08:32 PM
maro z28's Avatar
I read that too, but for the generally poor flowing exhaust characteristics of LT1s, you'll get more power out of a 1.6 set up than a split 1.6/1.5.
Old Feb 25, 2007 | 11:39 AM
2000GTP's Avatar
I would venture to say that alot of it is going to have to do with application. If an aftermarket cam or forced induction were in the picture, then I could see having different rocker ratios. However, if you are just using the rockers as a standalone bolt-on mod, I would just do a straight set of 1.6s.
Old Feb 25, 2007 | 02:27 PM
what about a full bolt-on with a cc503 , just use all 1.6's?
Old Feb 25, 2007 | 03:51 PM
2000GTP's Avatar
Just go with the straight set of 1.6s, that is what everyone else is doing and they are working fine.
Old Feb 25, 2007 | 10:06 PM
thats what i was going to do. I like using things that are already proven to work. was just curious..
scyzoryk
May 1, 2003 07:33 PM
Got-LT1
Mar 17, 2003 10:49 PM
97Z-M6
Feb 27, 2003 06:29 PM
treyZ28
Feb 14, 2003 11:09 AM
Ken95Z28
Advanced Tech
Dec 29, 2002 01:01 AM
