1.6rr.s and ported heads didnt pick up a thing
Old Dec 2, 2004 | 08:49 AM
Haskin Z28's Avatar
well i installed the comp pro mag 1.6 rrs with isky springs and ported the heads..i then order an all motor and nitrous tune from bryan..we put it on the dyno and it made the exact same numbers that are in my sig...however on those runs a/f was 13.0 now it was between 13.5-13.8..so we called up bryan and he said he went a little conservative on the timing and eh needs to richen it up..the graph doesnt look choppy or anything so im wondering where do you think the problem could be?
Old Dec 2, 2004 | 08:51 AM
Haskin Z28's Avatar
Re: 1.6rr.s and ported heads didnt pick up a thing
also we were wondering if its possible he mixed the labels up on the two tunes..as we have not installed the nitrous tune yet
Old Dec 2, 2004 | 03:03 PM
Haskin Z28's Avatar
50 views and nobody knows a thing?
Old Dec 2, 2004 | 03:11 PM
ARRFormula's Avatar
Maybe a rattle or tick causing knock retard, maybe from the RR's or exhaust rattle???
Maybe RR's aren't adjusted properly???
Old Dec 2, 2004 | 03:34 PM
The Cartel's Avatar
Stock cam?
Old Dec 2, 2004 | 04:01 PM
Haskin Z28's Avatar
stock cam with 1.6s rrs and ported heads
Old Dec 2, 2004 | 07:24 PM
Formula_one's Avatar
Seems pointless to me to pull/swap heads, but not a cam...?
Were the heads ported heavily or just cleaned up?
Old Dec 2, 2004 | 07:26 PM
SVThuh's Avatar
What knock module do you have? Also do you have a copy of the run in the form of a datamaster file? If so I would like to check it out.
Old Dec 2, 2004 | 08:08 PM
Haskin Z28's Avatar
ill see if i can get the datamaster on here, stock knock module and the timing was messing up the car badly so we had bryan send us a tune to basically delete the KM all together, he sent us a tune and also a nitrous tune, but we called him and he said he went conservative on the timing..so bascially im wondering if this all is boiling down to a timing issue
Old Dec 2, 2004 | 08:19 PM
Haskin Z28's Avatar
the heads were about as ported as they could be (take my word for it ) and when i say i cannot afford a cam..i mean..i literally cannot afford a cam, so all that none sense aside it still should be seeing plenty of more power
Old Dec 2, 2004 | 11:20 PM
lt4 fd's Avatar
sounds to me like it will produce a lot more power especially in the higher rpms like a cam, somewhat, but still pass emissions and have perfectly fine street manners. Good idea to me especially with the larger roller rockers...
Old Dec 2, 2004 | 11:37 PM
Spinner's Avatar
Odds are you did a sub-par port job and you didnt pick up any power.
Old Dec 2, 2004 | 11:42 PM
Z95m6's Avatar
Thats what i was thinking.
Old Dec 3, 2004 | 12:19 AM
dmoor88's Avatar
but how would you explain no gains with the rockers?
Old Dec 3, 2004 | 12:26 AM
Z95m6's Avatar
It sounds like he really hogged them out by the way he explained it. Maybe he actually hurt his flow with them.
