1.6 RR install.....sorry....
Old Mar 29, 2004 | 02:55 PM
  #16
Since my whole web article on valve adjusting was quoted, I guess I don't have anything to say.
Old Mar 29, 2004 | 03:02 PM
  #17
ibanez6rg's Avatar
It's easier on the eyes!
Old Mar 29, 2004 | 04:02 PM
  #18
30thannZ28's Avatar
Man I love this board! So much info to be learned! One last question remains tho....
If cylinder #1 and #6 are both at TDC right now, which valves do I adjust? Or which cylinder is REALLY at TDC?
Old Mar 29, 2004 | 04:21 PM
  #19
chy20k1's Avatar
Originally posted by HesterZ28
Tighten the rockers down about 4 threads take both valve covers off and adjust them while the engine is running.
doesnt that make a mess?
Old Mar 29, 2004 | 04:25 PM
  #20
Alex94TAGT's Avatar
30thann -- No, you've got it confused again. Re-read the thread.
You cant have both #1 and #6 at TDC at the same time. Only ONE cylinder can be at TDC -- not both. Ignore what Ibanez wrote about both cylinders being at the top of their travel at the same time -- thats not the same as TDC. You need to find TDC before you can adjust the valves.
Finding TDC:
-Method 1: As I've said three times, put both dots on the cam/crank gears at 12:00 -- that's #1 cylinder TDC (compression stroke).
-Method 2: you can tighten down two rockers on cyl #1 in order to watch the valves. If both valves are closed with the crank at 12:00 -- good, that's TDC (compression stroke). If the exhaust valve is open, then you need to rotate the crank one full revolution to get #1 TDC.
THEN you can follow any of the aforementioned rocker adjustment procedures. You can either adjust one cylinder at a time, or you can adjust using two crank positions to adjust various valves. When using a larger cam, I would not recommend adjusting all the rockers at two crank positions -- I would do each cylinder one-at-a-time (at TDC).
Old Mar 29, 2004 | 04:27 PM
  #21
gb95zconv's Avatar
Originally posted by ibanez6rg
Just read up on this.
Adjusting Valves and Zero Lash
Method 3
Another cylinder by cylinder method that does not require looking at the balancer position, follows:
(A remote starter switch is quite helpful)
Turn the engine in the normal direction of rotation until the exhaust lifter for a cylinder starts to move up, then adjust the intake valve to zero lash and add your preload. Turn the engine over again until the intake opens completely and then is almost all the way back down. Now, set the exhaust valve to zero lash and add your preload. Continue the above procedure for each cylinder until all valves are adjusted to the same amount of preload. This procedure will work for any hydraulic lifter cam with adjustable rocker arms.
Shoebox
Use this method and you dont have to worry about TDC....I do it this way and it always is right. No thinking involved here
Old Mar 29, 2004 | 07:17 PM
  #22
30thannZ28's Avatar
Originally posted by rpm4lalo
That is misleading, I would only use the above to change valvesprings, not to adjust the valves. You see when the crank dot is at 12 o'clock then you can remove the valve springs on the 1 and 6 cylinder since you don't have to worry about the valve falling into the cylinder. Then you turn the crank to 3 o'clock and remove the 5 and 8 cyloinder valve springs.
To adjust the valves you need to have the #1 cylinder at TDC, and by that I mean the the cylinder is about to fire the spark plug and it is at the top of its travel.
When at #1 TDC you can adjust the following valves:
Intake: 1, 2, 5, 7
Exhaust: 1, 3, 4, 8
Then you turn the crank one full revolution, now you are at #6TDC
you can now adjust the following valves:
Intake: 3, 4, 6, 8
Exhaust: 2, 5, 6, 7
OK, I adjusted my valves this way, and it was remarkably easy, which leads me to believe I did something wrong. When I look straight at the rockers from the side, they are all even and none of them are compressing the valves or springs. This is after I adjusted them. Is this normal? When I took the engine apart, the rockers were all compressed in some way shape or form. I'm afraid if I put everything back together now and start the car I will throw a rod or something! Someone ease my mind and tell me that's normal for newly adjusted rockers to be all level...
Old Mar 29, 2004 | 07:28 PM
  #23
rpm4lalo's Avatar
Between 9 o'clock and 12 o'clock as you turned the crank, did the exhaust valve on the #1 cylinder go down(the pushrod go up)?
If the exhaust vavle did NOT move as you were going from 9 o'clock to 12 o'clock then you are #1 TDC.
Adjust
I: 1, 2, 5, 7
E: 1, 3, 4, 8
Then rotate the crank 1 full revolution to bring #6 to TDC
Now adjust
I: 3, 4, 6, 8
E: 2, 5, 6, 7
Old Mar 29, 2004 | 07:52 PM
  #24
30thannZ28's Avatar
yeah, I got all of them adjusted, but my question is: Am I supposed to tighten the rocker nut all the way down on the outside part, and then adjust the rockers to zero lash with the hex key? or do I leave the hex key part level with the top of the rocker nut and go from there like I've already done?
Old Mar 29, 2004 | 08:26 PM
  #25
IrocSS85's Avatar
Intake: 1, 2, 5, 7
Exhaust: 1, 3, 4, 8
Intake: 3, 4, 6, 8
Exhaust: 2, 5, 6, 7
this is the method in the GM manual. this is also the easiest since you only have to turn the crank over once. one thing you guys arent expressing is you need #1 TDC on the COMPRESSION STROKE. this is when the piston is at the top, AND both valves are closed. thats the difference in TDC for the compresion stroke, and TDC for the exh. stroke. so just get the arrow to about the 11o'clock position, then have someone watch the valves on the #1 cyl. as you finish moving the crank (dampner arrow) to the 12 o'clock position. if the exh. valve is moving, then go around one more time and that will be #1 TDC COMPRESSION stoke. all TDC stands for is top dead center. (or, the piston is at the top of its travel up). TDC does not mean only on the compression stroke. and thats why #1 and #6 are both at TDC at the same time, but only one is on the compression stroke, and can have the valves adj. w/o turning the crank over a full revolution.
Old Mar 29, 2004 | 08:36 PM
  #26
IrocSS85's Avatar
I was away when you typed this. you have it wrong. the inside allen bolt is the lock only. the big nut is what makes the adj.. so you need to back out the allen bolt so it doesnt interfere w/your adjment. when you adj. a valve, you slowly turn the big nut until there is no slack between the pushrod and the bottom of the rocker, then you turn it 1/4 more turn only, and hold the nut still while you tigten the lockbolt w/the allen wrench.
if you tigten the big nut all the way down, you will compress the lifter plunger. if you have already done this, Id loosen them all up, and let it sit for an hour or so to make sure the plunger returns to the top before you make your real adj.ment.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
