I just installed the lt4 hot cam with the 1:6 roller rockers. Are the 1:6 roller rockers supposed to be queit or nosiey??. Please let me know
I have not heard the RR's on the Hotcam kit, but from my understanding they are the Self Aligning 1.6 type RR's. If that is the case, they are generally louder than the Non Self Aligning 1.6 RR's. If you didn't use guideplates, then you have the SA type.
You may want to adjust them with the engine at normal operating temps, with the engine running. I believe Shoebox has a nice writeup on how to do so.
How does the cam feel? Have you taken it out for a run yet?
Dan
Dan
They are much noisier than stock stamped rockers thats for sure, especially if you are using the stock valve covers. I got a set of LT4 composite valve covers after I installed the hc kit and it quited them down a good bit.
I put crane 1.6 on my 94 LT1 Vette and the ticked pretty loud compared to stock.
The 1.6 LT4 rockers I'm using have always been loud as hell. No matter how many times we've adjusted them, they have always ticked like crazy. Thicker valve covers helped a little bit, but you can still hear them.
