1.6 roller rockers??
Old Nov 16, 2011 | 08:18 PM
bencher's Avatar
What makes 1.6 rockers either fit an LT1 or not? Seems like it would be a universal part for all 350 motors. Are some brands able to be exchanged with stock ones without having to make any clearance in valve covers?
Old Nov 16, 2011 | 08:29 PM
Jlo's Avatar
Jlo
Re: 1.6 roller rockers??
The LT1 rockers are Self Align rockers you'd have to run guide plates if you choose to run standard 350 rockers and harden pushrods..The Self Align rockers are a bit high in price but bolt on without any use of guide plates and sometimes modification to the valve cover..The only issue is the Valve cover rails on the bottom some cut them off others just straighten with some visegrips to clear the rockers. Also if you change rockers make sure you change valve springs since stock will not be able to handle the added lift.
Old Nov 17, 2011 | 06:36 AM
RamAir95TA's Avatar
Specifically you need narrow-bodied rockers.
Old Nov 17, 2011 | 02:42 PM
6SpdLT1Z's Avatar
Like stated earlier you will probably have to clearance the bracing on your valve covers. Some rockers don't require it, but it's probably not a bad idea to give yourself a little extra clearance just in case.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Z Power
Sep 19, 2015 11:19 PM
