1.6 roller rocker question.....
Old Oct 2, 2007 | 01:58 PM
95 Civic's Avatar
Can I install my 1.6 roller rockers in wrong....
I just did a few mods to my trans am and I feel like its slower than it was.....
The roller rockers are the only thing that make me worry....
Old Oct 2, 2007 | 02:35 PM
Not enough details...
Old Oct 2, 2007 | 03:03 PM
2QUIK6's Avatar
Originally Posted by 95 Civic
Can I install my 1.6 roller rockers in wrong.....
Yes
A number of things....too much preload when you tightened them down would be the #1 thing..... Used NSA rockers with no guide plates and now the rockers are crooked over and off the valve stem. Or used SA rockers and the SA tabs hit the retainer and popped off a few springs.... valve train geometry is off..... lots of things, its not just a bolt on part if you don't know exactly what you are doing.
Need more info as mentioned by sb.
Old Oct 2, 2007 | 03:39 PM
Don 97 SS's Avatar
To add to what has been said above, you also won't feel any difference with just the 1.6 rr upgrade even assuming you installed them properly.
Old Oct 3, 2007 | 01:29 PM
95 Civic's Avatar
Yea, I didnt expect to feel a gain in power just yet, I added. 1.6 roller rockers, hardened pushrods, LT headers to a ORY with glasspack, went from 2.73 to 3.42's and also did a TH350 swap....
Old Oct 3, 2007 | 01:42 PM
Ok4thGen's Avatar
your going to have to pull the valve covers and verify that the valves are set correctly, however someone correct me if im wrong but the lack of performance your speaking of could be due to the different first gear ratio of a 4l60 to a th350.
Old Oct 3, 2007 | 02:46 PM
ttop1986's Avatar
Did you change the valve springs? If not, you probably should have.
Old Oct 3, 2007 | 02:50 PM
njenson's Avatar
a tune probably wouldnt hurt either
Old Oct 4, 2007 | 07:25 AM
95 Civic's Avatar
I have new valve springs but I never put them on.... didnt think it needed them until i put the cam in....
Old Oct 4, 2007 | 07:36 AM
Most people would recommend you put in new springs with 1.6 rockers, just to be on the safe side.
13qtr
Oct 28, 2016 08:11 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Z Power
Sep 19, 2015 11:19 PM
