1.6 rocker help
1.6 rocker help
i want to run a set of 1.6 rockers on a stock heads/cam car but i need help with a couple of things.
-if i run self aligning rockers, would you suggest running with some comp 7/16 studs or are the stock ones fine?i will be running lt4 springs,retainers, and locks.
-if i run nsa rockers what afe the pros/cons of these rockers?what else would i need to run nsa's?
thanks.
thanks.
Re: 1.6 rocker help
i finally found some stuff from the search, and i think im going with stock rocker studs, and probally some SA rockers, but has there ever been a proven hp advantage over sa to nsa's, i heard that they are more reliable, but is there a hp advantadge with the nsa's???
Re: 1.6 rocker help
