1.5 and 1.6 RRs
Old Feb 19, 2008 | 08:52 PM
williamfvc's Avatar
1.5 and 1.6 RRs
What is better? all Rockers 1.6 or 1.6 intake 1.5 exhaust?
Old Feb 19, 2008 | 09:15 PM
al 96 Ram Air T/A's Avatar
That's a question with no real answer.
It all depends on the specs. of the cam and what your goals are.
Old Feb 19, 2008 | 09:22 PM
williamfvc's Avatar
Ah ok, the engine have the stock heads and cam.
Old Feb 19, 2008 | 09:33 PM
lt1-xjs's Avatar
All 1.6's and you need to upgrade the valve springs.
Old Feb 20, 2008 | 06:34 AM
2000GTP's Avatar
Just run the 1.6s,especially if it is going to be a standalone mod.
Old Feb 20, 2008 | 07:40 AM
And most importantly, make sure they are roller rockers. Just swapping out the 1.5 stamped steel rockers with 1.5 roller rockers will yield improvements, as the stamped ones had very loose tolerances (anywhere from 1.45 - 1.55).
A quality roller rocker will decrease frictional losses and optimize each cylinder's potential due to tighter tolerances. By increasing the rocker to 1.6, you are effectively changing the cam without having to change the cam.
But like others said, keep an eye on the springs. You will be close to bind when gong to 1.6. On the stock cam, as long as you don't spin it beyond the stock rpm's, you'll be fine.
Old Feb 20, 2008 | 09:31 AM
9formula4's Avatar
Hes right on that one. The stock springs will be fine as long as you dont take it past 5800 rpms.
Old Feb 20, 2008 | 09:45 AM
2000GTP's Avatar
I don't know, considering how cheap you can get a set of springs, especially the LT4s, it is rather cheap insurance.
Old Feb 20, 2008 | 10:10 AM
Cheap insurance...yes.
But it requires quite a bit more work. Time is money...
Old Feb 20, 2008 | 11:19 AM
2000GTP's Avatar
True, time is money. But then something like this could fall into the pay now or pay later category.
Old Feb 20, 2008 | 02:31 PM
williamfvc's Avatar
Thanks to every one.
Old Feb 20, 2008 | 02:49 PM
Iceman_19's Avatar
I dont know about chevy motors, but i know a mustang mag did a test with 1.6 and 1.7 RRs on a motor, the best power was made with 1.6s on the intake, and 1.7s on the exhaust. Will it work the same way for all motors? Who knows, just food for thought.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
MDZ28
11
Sep 24, 2015 09:15 AM
