1/4 turn on LS7 lifters not enough?
Old Jun 29, 2007 | 09:29 PM
mobleman's Avatar
I plan on adjusting these again tomorrow afternoon but figured I'd ask for some opinions. Brand new LS7 lifters, (and brand new PAC 1218 springs) all adjusted to 1/4 turn past zero lash while the motor was running. I get a tick now which gets louder as the motor heats up.. Checked all the spark plugs and for exhaust leaks, and am pretty sure its valvetrain noise. Is it possible that I don't have the ls7 lifters preloaded enough? I've read some other posts stating 1/2 turn, and even the GM stated 1 full turn..
Any thoughts are appreciated!
Background: had to change the Comp Cam beehive springs, had 3 broken in under 1500 miles on newly rebuilt motor. Since I was swapping out the springs I figured I'd also replace the Comp R lifters for ease of mind. Bought the LS7 lifters, soaked them in oil for an hour and then installed.
Old Jun 29, 2007 | 11:56 PM
speed_demon24's Avatar
All the LSX people set their cars up for ~.060-.070 preload, but according to some engine builders on here you get the most power as close to 0 lash as you can get, but the valvetrain will also be noiser that way.
Old Jun 30, 2007 | 06:08 AM
mobleman's Avatar
Interesting... Anyone else with any input? Have to spend the day helping my Brother put a roof on his 2 room addition, so I cant reset the lash until tonight. I'll post back my findings shortly afterwards.
Old Jun 30, 2007 | 12:48 PM
stereomandan's Avatar
I'm not sure how they compare to the stock LT1 lifters, but optimal for the LT1 lifter is 1/2 turn if you have 3/8" rocker studs, or 3/8 turn if you have 7/16" studs. (due to the difference in thread pitch)
I forgot the thread pitch for the 3/8 and 7/16" rocker studs, so I can't calculate how far you need to go to get to 0.060" preload on the LSx lifters.
Dan
Old Jun 30, 2007 | 12:52 PM
Dan
With 7/16 studs every 1/4 turn was about .020 preload. I measured this with a dial indicator since you can't just use thread pitch since the pushrod sits back and goes down faster than the thread pitch, I don't know what the ratio is though.
HectorM52
Jul 30, 2017 11:46 AM
dfarr67
Apr 10, 2015 07:44 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Bearmans
Dec 3, 2014 05:28 AM
formula79
26
Aug 5, 2002 12:21 PM
