02 Z06 Cam and LT1
Old Aug 10, 2004 | 06:31 PM
Mir Hussain's Avatar
Arrow 02 Z06 Cam and LT1
If I were to create or make Custom made the CAM; with 02 Z06 cam profile. Will it work? What will be pro and what will be con ?
Lets discuss
Mir
Old Aug 10, 2004 | 07:26 PM
jchevy's Avatar
Re: 02 Z06 Cam and LT1
If you going to have a custom cam ground get it so it works with what you have. It would make no sense to me to put a zo6 cam profile in an lt1.
Old Aug 10, 2004 | 08:15 PM
Camaro_Maniac63's Avatar
Profiles of the camshafts for the LSx seem to be very different from the cams for the LTx engines. The heads and the intake manifold of the LS1 are superior as cast, therefore they allow for the use of cams with tighter LSAs and moderately higher-lift. I believe the Z06 cam has a 116* LSA, which wouldn't be very optimal for a LTx engine.
Old Aug 10, 2004 | 08:49 PM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
I think you are trying to be creative.... But as said before, the engines are too different.
Old Aug 10, 2004 | 09:28 PM
Mindgame's Avatar
The cylinder heads are about as different as they get. They both have one intake and exhaust valve.. that's about where the similarities end.
The Z06 cam was designed with the cylinder head and valvetrain (springs, valves, everything) in mind. It was likely a compromise on power and emissions.
-Mindgame
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
InfernalVortex
Jan 17, 2015 09:35 AM
hotrodyou1
Dec 20, 2014 10:05 PM
