02 sensor problem, help!!!
Old Feb 2, 2005 | 06:43 PM
jaredwayt's Avatar
i got a problem, my car was running like crap, it felt like it was running on 6 cylinders, so i had a diagnostic test done, and it was a 02 sensor, so i was wondering if i could replace the factory sensors with simulators, to save me a a lot of money.thanks...
Old Feb 2, 2005 | 06:51 PM
Re: 02 sensor problem, help!!!
Simulators are only for the post cat sensors on cars that have them.
Old Feb 2, 2005 | 07:12 PM
jaredwayt's Avatar
i dont understand, my car is a 96'ss lt1, it has 02 sensors after the cats, i was wondering if i could just plug in the simultors to cure my car from running like crap, instead of having gm replace the 02 sensors with factory units.
Old Feb 2, 2005 | 07:21 PM
Dave89IROC's Avatar
your car has 4 o2 sensors, 2 before the cats (provides PCM with info for fuel trim adjustments), and 2 after the cats (to provide PCM with cat efficaincy info for cat health calculations/DTC flags), it is only the 2 after the cats that can be replaced with sims
Old Feb 2, 2005 | 07:27 PM
jaredwayt's Avatar
so do you think that the simulators would fix it if it were accually the rear 2 sensors that were bad???
LT1WanaBe's Avatar
Or you could just shell out a few more $$ and do the job right the first time around. I mean, hell, I look forward to **** breaking on my LT1, afterall, I gota all the room in the world to work with I'd do it right the first time, get factory/OEM replacements so you don't have to work in the realm of no room any sooner than you'd like.
~Jon
Old Feb 2, 2005 | 07:30 PM
Bersaglieri's Avatar
Thread starter you need a sig with year and model vehicle and mods so we can more easily assist you.
-Dustin-
Old Feb 2, 2005 | 07:45 PM
Dave89IROC's Avatar
the rear sensors will not effect how the engine runs, other then setting a DTC and turning on the light, only the fronts are needed for correct engine operation, so , no, sims will not help this problem
Old Feb 2, 2005 | 07:47 PM
jaredwayt's Avatar
yea, sorry about that, im getting to it, and i really dont want to spend alot of money that i dont have so i was wondering if it could be a quick fix for like 50 bucks, not 300, just a thought...
btw its a stock 1996 camaro ss m6
Old Feb 2, 2005 | 08:09 PM
You can alway put sims in for the rear sensors and then you would not have to worry about them. Of course, that won't help with driveability problems from the front O2 sensors.
In your first post, you did not give much info to go on. No year of car or indication of what particular DTC was given (there are about a dozen or more O2 codes for OBD-II cars). It makes it hard to give an informed response.
Old Feb 2, 2005 | 08:31 PM
jaredwayt's Avatar
yea sorry about that, but thanks again for clearing up some info, i guess all i can do is buy the sims, or would it be possible if i buy a new y-pipe, that would elimnate the cats, would i still have to retain the front 02 sensors???
Old Feb 2, 2005 | 08:57 PM
mohawkmike's Avatar
Just because you have an O2 code doesn't necessarily mean you have a bad sensor either. It could be a number of different things.
Old Feb 2, 2005 | 09:18 PM
The front sensors MUST be retained. Even if you remove the cats, you will still need the sims (that is actually why most people use the sims in the first place).
HectorM52
Jul 30, 2017 11:46 AM
eazyZ
Mar 1, 2015 07:12 AM
MattFick
Feb 15, 2015 10:16 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
