02 sensor problem...
Old Jul 10, 2005 | 03:31 PM
wb3s94z28's Avatar
O.k...so i got a code...left 02 sensor lean. So i throw up freescan check the voltage, and it won't go over 4 mv. So i replace them (since they are the origional sensors with 118,xxx on them) and check it again...it throws it again. It's still at 4 mv. Anyone had this problem before? I checked the wiring harness and their is no damage that i can tell of. Also, this happened after i installed my long tubes....
Old Jul 11, 2005 | 11:15 AM
wb3s94z28's Avatar
Re: 02 sensor problem...
Anyone?
Old Jul 11, 2005 | 05:27 PM
nb 96 z's Avatar
I have the same problem but havn't fixed it. I also checked the wires and connectors for damage and still have gone through new o2 sensors. I know I don't have any exhaust leaks either.
Old Jul 11, 2005 | 06:33 PM
ZMAN Z28's Avatar
do you have 5 volts at the connector give or take a little?
Z
Old Jul 11, 2005 | 11:38 PM
Pyro97's Avatar
is there any oil or anything getting on the plugs for the O2 sensors? I had an oil leak and the oil got doen into the plug and messed up the sensor.
Old Jul 12, 2005 | 07:38 AM
Did you use harness extensions when you added the long tube? Check the extensions for a broken or shorted wire.
Old Jul 12, 2005 | 10:16 AM
wb3s94z28's Avatar
I did have the line to an old oil pressure guage break from the secondary outlet down their the first day i had the long tubes. Whats the best way to clean that? I know it isn't the extensions. I extended the wires on old ones the first time, and then when i bought my new ones i bought extentions.
Old Jul 12, 2005 | 10:18 AM
wb3s94z28's Avatar
Z
Which wire should i have 5 volts at?
Old Jul 12, 2005 | 10:58 AM
ZMAN Z28's Avatar
I am pretty sure they run off of 5 volts. Unplug the sensor, and with the key on, check the 4 wires for voltage. Sorry I can't remeber which one/s should have voltage. I'm sure someone on here should know. Sorry I'm not giving great advice. If it isn't 5 volts, then its 12 volts.
Check out this schematic:
http://shbox.com/1/HO2S_connector.jpg
Z
Old Jul 12, 2005 | 01:06 PM
The sensor heaters get 12V on the pink (+12V) and black (ground) wires.
The sensor element itself has a ground (tan wire) and a signal wire (purple or purple/white). The PCM sets a bias voltage of 0.450V on that circuit and the O2 sensor adds or subtracts from that voltage making it range from 0V to 1.0V.
To my knowledge, there is no "5V" circuit to the O2 sensor.
One more try.... did you check the extension? Just because its new doesn't mean its "OK" or that it didn't get damaged at some point. Would seem to me that it would be a good idea to check the continuity on each wire in the extension. Or, if physically possible, swap the extensions left to right and see if the problem follows the extension. At least that way you would rule out the extension.
Old Jul 12, 2005 | 06:08 PM
ZMAN Z28's Avatar
Sorry, I knew it was either 5V or 12V. Thanks for the clarification.
ZMAN
Old Jul 12, 2005 | 11:27 PM
wb3s94z28's Avatar
I'll try that, but i had the old ones hard extended with wires and now the new ones with extensions and they same problem....i'm going to check but i have sorta ruled that possibilty out
Old Aug 13, 2005 | 02:59 AM
Silvershark's Avatar
I know this is an old thread... but I was just curious what the fix was. I am having the same exact issue on my car. Same side of the engine bay. New sensors as well.
98-LS1Z28
Sep 8, 2015 03:12 PM
MDZ28
Sep 7, 2015 09:16 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
