0 oil pressure and screeching noise..?
Old Apr 17, 2011 | 10:59 PM
camz28ryan's Avatar
I have a 96 camaro z28, 171,??? miles. Lt4 hotcam, I have a mechanical oil pressure gauge, and at idle i have no oil pressure, if i rev it up to 1500 rpm i will have about 12 lbs, it also makes a screeching noise from time to time, its not a consistent noise, just kind of random. Also the idle is messed up too, it will fall down to 500 rpm, and die sometimes too. wth is going on?
Old Apr 18, 2011 | 04:58 AM
RamAir95TA's Avatar
Re: 0 oil pressure and screeching noise..?
STOP RUNNING THE ENGINE.
Zero oil pressure means your bearings are wiped out. The screeching you hear is metal-to-metal contact. It's time for a rebuild.
Old Apr 18, 2011 | 09:14 AM
USAFretired's Avatar
+1 on on that comment.
Old Apr 18, 2011 | 09:17 AM
bw_hunter's Avatar
Look at it as an opportunity to build something, not the complete destruction of your bottom end (which it is)
Old Apr 18, 2011 | 10:25 PM
camz28ryan's Avatar
yeah we did park it. We were planning on the rebuild anyways thanks though!
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
