"0" oil pressure :(
Old Apr 14, 2008 | 07:53 PM
DIYAR21's Avatar
"0" oil pressure :(
my LT1 suddenly started make weird noise from left side of the motor. just like cobra head tick. only from driver side head. this happened 2 weeks ago. i got on it once to speed up quickly to 6k RPM and then once it shifted to 2nd gear i let go. i parked and went to work. at night when i started it it, i noticed that bad tick from driver side head. any idea what could that be? also now when i start the car, cranking sound kinda got louder, almost like something rubbing. i have to get that tick thing fixed but not sure what it is. do u think driver side head is messed up? or motor on its way to blow up?
by the way, just checked and relaized the car has absolutely "0" even below zero oil pressure! what should I do guys?
what this could be?
Old Apr 14, 2008 | 07:59 PM
hotrod18_69's Avatar
Not good. That's a spun rod bearing. Which = rebuild time. Sorry man..
Old Apr 14, 2008 | 08:01 PM
DIYAR21's Avatar
the car is not worth to rebuild. she is still running. i dont mind if she performs not good, as long as she runs for a few more months, i am ok. is there any way to get her run for a while at least? (might be a dumb question but gotta ask)
thanks.
Old Apr 14, 2008 | 08:05 PM
If you have "0" oil pressure. It won't run for much longer. 15 mins. if your lucky. I highly suggest not driving it anymore.
Old Apr 14, 2008 | 08:07 PM
DIYAR21's Avatar
lol i am at work and my house is 15 minutes away! maybe i can make home. i guess i will part her out then. damn it, i now have to buy a car?
thank you for your help sir.
Old Apr 14, 2008 | 08:12 PM
Well good luck. Just keep the RPM's as low as possible. No higher than 2500. But with "0" oil pressure. I'm betting you won't make it. Towing it would be best, but if you have to drive it. As least have a friend follow you home..
Old Apr 14, 2008 | 08:20 PM
DIYAR21's Avatar
thanks man! I will call wife to come to follow me. maybe once i part her oput, i will be able to get like 1500 out of her total to feel better. i rebuilt that tranny 7k miles ago
Old Apr 14, 2008 | 08:36 PM
ARZ28's Avatar
if the body is in good shape you could get more than 1500.00.people are always looking for a good body to put a motor in.try ebay ive seen firebirds with bad motors going for over 2000.00
Old Apr 14, 2008 | 09:06 PM
Red93Camaro's Avatar
That sucks, I'm sorry man. Do you have stock exhaust?
Old Apr 14, 2008 | 09:12 PM
DIYAR21's Avatar
thanks a lot man! since the day i bought this car, it had problems! the car is sompletely stock with only flowmaster wvelded in to stock pipes.
Old Apr 14, 2008 | 09:24 PM
Meh, Youll find a better one soon.
HectorM52
Jul 30, 2017 11:46 AM
Nickster 7
May 1, 2015 09:04 PM
surreybrad
Apr 22, 2015 06:40 AM
KYWes
Apr 15, 2015 05:48 AM
ad356
Apr 11, 2015 08:49 AM
